Stock Cervelo Black Stem
Fits on 1’ only, and I believe its clamp is regular 26 mm size. Not sure of the rise, length is either 100 or 110mm, but looking to sell cheap, used very little. It came off Cervelo Dual. Email me with reasonable offers.
Oval concepts R700 stem
Stem is 120mm with 1 1/8 and 26 (undersize claim) I used it with the A900 series aerobars USED
The rise is 84°
Oval concept double bend aerobar carbon extensions: $100
Going from tip to tip (diagonal see picture) they are exactly 1 foot (12 inches). The body straight section is 6 inches. These easy fit the shimano bar end shifters. There are a few cosmetic scratches at the end of the bars but no damage to the bars. These can be used for internal routing of cable (hole on underside)
Here is the information on the double bend carbon extensions
Member HED, Cervelo, De Soto Mafia
The rise is 84°
- Great looking, reliable lightweight stem
- RBT® eliminates key fatigue failure point
- Triple DIN security at a very light weight
- Marine SS bolts reliability & no rust
- Blue Loctite® so bolts won’t rattle loose
- Bias cut & opposing bolts cradle carbon steerer for added safety
- 180ş bar wrap reduces bar & bolt stress
- Finely finished edges cradle exotic bars
- Matt Black body w/ Pearl Silver front cap or
- Stack height = 40mm/26.0
- 120g/26.0x80mm clamp
- Retail $65
- Original three position aero extension
- Allow short, high leverage position for climbing
- Allow two long, low positions for descending
- Pre-drilled for internal cable runs
- 295x22.2mm tube with 2-30 degree rises
- PPA carbon construction for strength and lightweight
- Alloy front cap for shifter expander
- Available in clear coat carbon
- 110 grams
- Retail 129.00 (Not looking for that price MAKE OFFERS)
