I’m looking for an all-round wheel for my road bike, something I can train and race on in situations where I don’t want to go with a high-end full carbon wheel.
Alloy brake track, wider rim, aero over weight, ideally under 1k.
The zipp 101 seems like the best choice … does anyone have any other suggestions? I’d go with a Jet 5 (I can get a deal), but I wonder if it would actually be better.
get a set of HED Belgium clincher rims built up on a nice set of hubs, CX ray spokes if you really want to get fancy…the difference was noticeable moving to the 23mm wide rims and running lower pressure.
The new Belgiums should be even closer to the 101 (wider, with angled brake track). Not sure when they’ll be available or how close the profile is, but I’m waiting for them myself.
Allow brake track, wider rim, aero over weight, ideally under 1k.
Customs with the Kinlin XC279 or Pacenti SL23 would be your best bet. Those rims are a little shallower, but are nicely rounded and probably as aero as the 101. You could get some really nice hubs and stay under $1k.
HED Ardennes, HED Belgium based customs, Kinlin XC279 customs, Velocity A23 customs, Boyd Vitesse and save some cash in the process, Neuvation’s new wider alloy wheelset and save even more cash.
All good options for what you’re describing.
The Jet 5s would definitely give you an aero advantage over any of these at a small weight penalty but if you’re looking for wheels to race as well as train on it’s hard to beat the Jet series. If you go down that path then Flo 60s are another option with alloy brake tracks and a wider rim bed with a nice deep aero cross section, Flo is expected to come out with a shallower Flo 30 wide wheel soon which will likely be another candidate that meets your description similar to the wheels listed above.
Zipp has a new wheel, the Z30. It has an aluminum rim, wider at the brake track (20.4mm), weighs 1650g and a MSRP of $850. I believe it will be available sometime in March but I’m sure if you call your LBS they can give you more info.
I was in your position and ended up with two sets of shamals,
one tube less, the other not, love them. training and racing
you can find something on ebay for close to 1k
Has SRAM discontinued their S-series wheels? The S30 sounds pretty similar to the new Zipp 30, but I don’t see any of the SRAM wheels (S30, S60, S80) on their website anymore.
Yeah, the product line is being re-branded as Zipp. The marketing manager in me isn’t sure that’s a great idea since the Zipp brand has become synonymous with high-end, hand-built wheels, and this sounds like brand dilution to me.
I think this is the same rim as the Boyd Vitesse (or it’s very similar).
EDIT: I see that rruff has suggested the same rim, the Kinlin XR-279. The Pacetti SL23 looks a little nicer (lighter, wider, perhaps more aero just by the looks of it) but is more expensive.
On my list for this year is a set of Hed Belgiums laced to DT Swiss 350 hubs. I’ll probably get the hubs new off ebay and the wheelset will be waaaay under $1000. I’m really looking forward to this set.
