Greg,
Hi! I’m not sure who wrote your reply to my article at cyclingnews.com… but there’s some seriously wrong ideas in there, which are neither supported by the scientific literature, and are further not supported when empirical observations are made.
Specifically, the idea that an AG or (indeed) anyone (who is healthy) couldn’t generate the forces required to reach VO2 max/peak is erroneous. Looking at a wide range of (male) subjects, VO2 max (during an incremental test to exhaustion) would result in a mechanical power output of ~ 300 - 600 W (for low fitness right up to the very best in the world). The power that most (males) can generate during a 5-second peak power (sprint) test, will be in the range of 800 to 1400+ W (for endurance athletes of say 60+ kg), even accounting for the higher cadence in the sprint, the forces that would need to be applied, would be considerably higher, often in the region of 50% more. As power = force x velocity, you can easily calculate the ratios. Thus, triathlon, which is an endurance sport, and not one that requires maximal force (like cycling) needs very little strength.
I don’t disagree that strength is increased in the gym. it’s just not warranted for such a sport that requires very moderate* amounts of power output such as cycling and triathlon. *refers males generally riding in the range of 150 - 400 W for tri/cycling, when peak power will be >800 W.
I don’t argue that many AG, elites (cyclists and triathletes alike) need to increase power output. However, the power that needs to be increased is sustainable power (i.e., TT power) and force application just isn’t a limiting factor. What limits performance here is power at LT, with VO2max/peak being the rate limiting mechanism. Along with power at LT, you need to be looking to increase capillarisation, type I fibres, mitochondrial density, oxidative enzymes etc. None of these are increased (actually, none are stimulated by weight training in reasonably well trained athletes, which is anyone who works out regularly in preparation for races – be that tri or cycling).
It’s actually efficiency that is measured within cycling, and leaving aside any arguments/discussions about Power Cranks, or Rotor Cranks, efficiency varies very little in cycling, primarily because your legs/feet are fixed to the pedals, and can only move in a fixed manner – thus, cycling is a very simple motor control sport. Accordingly, at a given workload, and a fixed cadence*, two different athletes (but same size) who are at opposite end of the fitness spectrum, will produce the VO2 for that workload, i.e., their energy expenditure will be the same. *At a given workload, different cadences will produce different efficiencies, such that efficiency increases at lower than optimal cadences. as the workload increases the most efficient cadence rises
As i suspect, that many people here are AG or time limited, the best thing to do is to concentrate on the 3 areas of swimming, cycling and running (and for any cyclists only who are reading this, just cycling). any time you concentrate on moving away from this ideal you are loosing valuable training time.
There are reasons to do weight training, but these aren’t associated with cycling performance (e.g., some form of muscle atrophy - because you’ve broken a bone, etc.)
Ric Stern
ric@cyclecoach.com
