Wellllll…even the “efficient at lower cadences” question has not be put to rest.
Two more quotes:
"*There is no disadvantage to pedaling at high cadences provided that power outputs are greater than 70% of an individual’s maximal aerobic power.(Adapted from Sidossis et al Int I Sports Med,. 13(5), 407-411], 1992 .) " *If you’re really motoring, there is no efficiency penalty for higher cadences.
*"These data suggest that muscular efficiency, as reflected by delta efficiency, may be enhanced at higher cadences. (Adapted from Sidossis et aL rnt J Sports Med, 13(5), 407-411,1992.) " *Your power can go up faster than your usage of energy goes up at higher cadences.
“Efficiency” is defined here as relating work done to energy expended. Delta efficiency relates the rate of change of work done to the rate of change of energy expended (ie, the first derivative).
The assertion that faster cadences enhance fatigue resistance is not an empty hypothesis by the authors. The study by Ahlquist cited makes rather clear that higher cadences reduce the reliance on fast-twitch fibers, leady inexorably to the well-reasoned notion that faster cadences can enhance muscular endurance.
"At any submaximal cycling speed, if we select a high cadence, the glycogen depletion study of Ahlquist et al (1992) suggests that we will minimize the recruitment of fast-twitch fibers. However, we can still supply ATP to the working muscles of the leg using predominantly slow-twitch or intermediate fibers. Since there is less reliance on fasttwitch fibers, there is less likelihood of a large increase in lactic acid in the working muscle."
" How then does the selection of fewer fast-twitch fibers effect the cyclist, and might this be the elusive answer as to why cyclists select high rpms during submaximal cycling? Slow-twitch fibers derive most of the energy necessary for muscular action via oxidative metabolism, in which glucose and fat are broken down and, in the presence of oxygen, large amounts of ATP are formed. ATP, or adenosine triphosphate, is the immediate source of energy for muscle action. In contrast, fast-twitch fibers break down more glucose than can be oxidized to carbon dioxide, which results in the production of lactic acid. While lactic acid can actually be reutilized as an energy source, in large quantities it has been linked to a decrease in muscle force production (see Metzger, 1992, for a thorough review of factors affecting muscle force production). "
The cadence question is not as clear as simple oxygen or energy consumption would first indicate.
