Tririg Ultimate Scoops SL - anyone using a set?
Has anyone here got a set of the tririg scoops sl ? I have been using their mini scoops for a while and really like them but fancy the idea of full length support but the original Ultimates were far too bulky in size. The new SL ones are narrower but their social media imagery is poor and only seems to show the older design.
Can anyone let me know what the SL design is like ?
I’m not sure about overall size, but I thought that the rests were simply lighter, but same size. I would be curious if they are smaller.
Apparently they are narrower but not having seen a set, I don’t know for sure.
To add to your question, I’m curious about the length and if anyone with “short” arms uses them? I’m small with a short reach and my forearms are much shorter than the 33cm scoop length so wondering if I can make it work.
By chance is anyone using the Scoops SL with mechanical shifting? I’m having a hard time understanding how the cable housing for bar-end mech shifters would route through/in/around/? the Scoops. Thank you especially for any detail pics!
The mechanical cables have to be run on the outside. They can follow the channel down and use electrical tape to secure it to the sides of the scoops.
IMG_0524.heic
Bumping this thread to see if anyone has had experience with these extensions and maybe has tested with them, I have already asked our aero guru’s Brian S. and Marc G. and they have not.
I have been running the Ultimate Scoops on my bike for this season. I can’t get over how comfortable they are. I spend more time in the aero position. I also seem to get more leverage pedaling with them compared to the other system I had. I would highly recommend them if you are considering purchasing a set. You won’t be disappointed.
Do you end up getting these? If so, curious on your thoughts.
Hey Steve, yes I did and I think they are terrific. Here is my set up on my new QR VPR-i.
Wow. That looks sharp. How is the weight with the overall setup? Do the scoops collect a ton of sweat and become slippery?
I doubt that they are the lightest option but the VPR-i is a very light bike. Yes you can get some puddles but they don’t get slippery, that foam insert has a grip texture to it.
My Wife used them on her Ventum at Ironman Texas and even in those Gail force winds on the toll road she said she was rock solid. She felt locked in and felt the extra forearm contact made all the difference when controlling the bike in the headwinds.
They look amazing!
I can see that the bars weigh in at 550g. Also that the base cup itself measures 330mm.
@Bryancd - could you help with the full lenght incl. the inserted carbon bars/extentions?? Maybe measuring both from the very back end and from where the elbow sits in the cup? Thanks a bunch
For my set up to the he tip of the extensions is 46.5cm
Thanks!! From the mid-elbow rest or the very back of the cup?
About 40cm
Awesome thanks @Bryancd
Put out an order already!
Besides weight, What is the difference between those and these?
Looks like something new is coming from tririg. Watch at the end.
