You should not be serious about your kick…
Open water swimmers do not kick, - or not much. You get next to zero forward propulsion from kicking. an overemphasis on kicking will serve to separate out and uncoordinate the timing of your overall stroke and slow you down.
Besides these factors, - moving around two big legs will serve to tire you out and faster. The biggest problem in triathlons is wasted energy on a trivial part of the race. In practice, triathletes go out way too fast, and expend too much energy at the beginning of the race and die on the vine by working the swim way too hard.
Swimming is an upper body intensive sport. You’d be better served by spending that time in the weight room doing lat pulls and bench presses. The swim stroke is all about a coordinated upper body application of strength and force. Real swimmers, and really fast swimmers, use pull buoys and hand paddles when they want to tear apart their stroke and look at stroke timing issues.
What’s the biggest way to improve Tri swimming, - swim for an hour straight without stopping, - you are likely to see yourself logging more and more and more distance in that amount of time.
The best prep that you can give yourself for the swim part of a triathlon is to be able to REST while swimming and saving your energy for those parts of the race that matter. Having a relaxed recovery and knowing how to rest, is a far more important bit of experience to develop than a strong kick that provides next to no propulsion, and mostly servers as timing mechanism to help you breathe.
As others have mentioned, these comments are completely OFF base, and all I can imagine is that they are in your AG and want to beat you.
The kick is THE MOST IMPORTANT aspect of the stroke and provides the basis for speed and body position. It’s akin to riding your bike without holding the handlebars, versus with.
to JReed: It was Mel Stewart…
to TOENAIL: I’ll race you: you - no kick, no pull-bouy, and you can choose the distance; me - any kick I choose, local to me.
THANK YOU!!! I was getting ready to do a google search.
He was all the talk…and everyone wanted to see if he would go into oxygen debt and pass out on the deck.
