Specialized Roval CLX white paper: more aero than Zipp NSW, lighter than Enve
https://www.bikerumor.com/wp-content/uploads/2017/01/Roval-CLX-50-Whitepaper-Summary.docx
So Specialized finally figured out how to make a brake track that doesn’t dissolve down a good descent-make a disc wheel.
Development notes: Specialized developed the CLX50 around a 24mm wide (spec) tire which measured 26mm when mounted. It appears they developed the rim around their own 24mm S-Works Turbo/Turbo Cotton casing. What’s interesting is that they have a graph showing rotational+translational drag.
My thoughts:
-The 454 NSW certainly doesn’t seem to bring anything game-changing to the party. IMO it better really be 303 stable if Zipp wants to justify its existence.
-I wonder how much better the Zipp wheels would have tested with a 23mm GP4000 SII? That seems to unofficially be Zipp’s go-to tire.
they would be better with a supersonic tire
looks like power to spin is negative from the unlabeled graphs
Too bad they didn’t publish rotational drag. It would be interesting to see if the study on JackMotts site reported similar values.
Also, as I read this it looks like they were designed around the Specialzed Turbo tire, but it doesn’t talk about the Turbo Cotton.
They tested with a 24mm Turbo Cotton
Nope, they were tested with their Turbo tire:
“Win Tunnel testing were all done around a Specialized S-Works Turbo 24c tire (measuring ~26mm wide)”
It’s nice that they included rotational drag, but then they go and mess up the axis (and I would like to hear how they measured the rotational drag, by the way). Why include units on the axis if you are not even going to put numbers on it?
Ah, thanks. I could have sworn they said Turbo Cotton somewhere in there.
Would rotational drag vary much between wheels of of the same rim depth? I imagine that the rotational drag is largely driven by spoke choice, and since there are so few choices when it comes to aero spokes it seems like they would all be very similar.
They did.
“The same tire and pressure was used for all testing – a Specialized Turbo Cotton 24c @ 100psi. (Actual measured width is noted in the graph)”
Confusing. Early on they claim they designed to tire around the Turbo S-Works Turbo 24c, but then they publish competitive test results using the Turbo Cotton 24c. Perhaps the performance delta to Zipp was less impressive on the S-Works Turbo?
I’m pretty sure the two tires are dimensionally identical.
Perhaps. This paper seems like it was done in a bit too much of a rush without proper review (mentioning different tires, no numbers on the axis).
I don’t think so. IIRC, if you look at Tom A’s wind tunnel data you will see that the Turbo tire is much more aero than the Turbo Cotton tire. I believe the manufacturing methods are different (with the Turbo Cotton being a “open tubular”, whereas the Turbo is not).
From the graphs it actually does look more like it’s the Turbo Cotton being used, since the drag is not decreasing much at yaw - which it usually is with a more aero tire.
They may have similar nominal specs, but the construction of the two is quite different and they presumably shape differently when inflated to the same pressure.
Tom Anhalt wind tunnel tested both (along with various other sized Specialized tires) on the same wheel (CLX64) and found considerably different behavior at yaw angles beyond 5*.
Actually, it says they designed around the S-Works Turbo, but the testing was with a Turbo Cotton.
I’m dismayed by the lack of units on the charts…at least tell us what each division represents. Otherwise, there’s no way of knowing if we’re looking at small or large differences :-/
Are the quoted wheelset weights with, or without braking discs attached to the disc models? My bet is “without”, based on the Enve and Bontrager weights. If that’s the case, then this is the second example of the wishful thinking about disc rims being able to be lightened enough to overcome the weight hit of de-integrating the braking surface not coming true…
I’d also like some more information about the “rotational drag” and how that was measured, and then “translated” back into an equivalent CdA. Is it possible the “translational” and “combined” values are just the drag measurements from wheel-stationary and wheel spinning measurements? If so, then that’s still missing the “power to rotate” contribution.
I DO like the fact that they do what they can to increase spoke bracing angle. Even small changes in that can have relatively large lateral stiffness effects. Damon Rinard found that out a long time ago when he looked at the lateral stiffness of a radially laced wheel, where the only change was a “spoke heads out” vs “spoke heads in” configuration in the lacing :slight_smile:
They aren’t…just because of the construction. There’s a “lip” on the TC where the tread is glued to the casing that’s not present on the Turbo
I see that now. Confusing. Smells a bit like the Turbo Cotton gave better results compared to Zipp (like mentioned above). Why else not use the tire you designed around? (Maybe they should have designed around the Turbo Cotton in the first place, but that’s another thing).
Yes, at least give us numbers for the divisions. I can see Mr. Yu cringe as he saw what the marketing department ended up with for a final release of this paper :stuck_out_tongue:
It was a much more aero tire on that wheel. It may or may not be the same on a different wheel.
Ah, gotcha. I wonder how it would have fared with the 24mm Force. That seems to be like a really good bet on the new generation of ultra-wide wheels.
True. But judging by how all “open tubulars” seem to do in aero testing (i.e., early stall), I wouldn’t bet too much money on the Turbo Cotton being an aerodynamically good choice on any wheel.
