Ok how did you quote/reply his post?
I was able to reset my password and stay logged in on my tablet, but none of my other devices work. I’ll likely wait until this is fixed to do any posting, other than this.
Lots of people trying to figure out how to use the new forum. We can probably collect some of the most common “how do I?” questions for easy reference. I’ll start with: How do I quote something in my reply? -There are several ways to use the quotes function in the new forum. You can highlight the text you want to quote with your mouse, and a menu will pop up above the text. If you click the quotation marks, it will generate a new reply with that specific text quoted and the poster’s name …
Cool, what are some of the other ways?
Click on the link in that section. I linked you to my post that had three or four ways.
50plus:Lots of people trying to figure out how to use the new forum. We can probably collect some of the most common “how do I?” questions for easy reference. I’ll start with: How do I quote something in my reply? -There are several ways to use the quotes function in the new forum. You can highlight the text you want to quote with your mouse, and a menu will pop up above the text. If you click the quotation marks, it will generate a new reply with that specific text quoted and the poster’s name …
Thanks. Cheers.
I thought I saw it somewhere but how does one set things up to see a reply within an answer only? I’m seeing the reply nested within an answer and then the same reply at the bottom of the thread. The reply at the bottom of the thread doesn’t tie it back up to original op so it makes it a little confusing.
I thought I saw it somewhere but how does one set things up to see a reply within as answer only? I’m seeing the reply nested within an answer and then the same reply at the bottom of the thread. The reply at the bottom of the thread doesn’t tie it back up to original op so it makes it a little confusing.
Very confusing!
Just hit the End key on your keyboard.
The scroll bar works.
Having said that, my keyboard doesn’t have an end key.
I purposefully bought a simplified keyboard because of where it sits on my desk.
