Poll: What cycling computers are you using on aerobars
As I continue improving my designs I need to know what cycling computer is most common on your tri bikes.
I use wahoo bolt. What Garmin is your choice? Other? Please help comment so it helps me plan a new idea based on weight/ size of computer into the next design.
Thanks
Garmin Edge 530
I have a Roam V2 on mine. Good balance of visibility and size.
Garmin 840
Edge 130 Plus
edge 130 plus
Bolt V2. I regret it though, as it’s rather difficult to see where it is I need to turn. It’s a great computer if you have your turns mapped out mentally or don’t mind stopping/blowing through intersections you meant to turn at. Should have bought the roam.
Seeing Garmin Anti-Container pricing and update practices means I will never switch sides of the isle. I still get feature updates from Wahoo!!!
Edge 1030…..Backup is the 820
What are you currently using to mount that?
I use a Garmin 840 between the extensions. The 1050 is too wide to fit there with the quarter turn mount, otherwise I would use that instead.
Same
Edge 1050
Big fatty Garmin 1050
Garmin Edge 840
Just upgraded from the Edge 1030 to 1050 and it a big improvement
I use mostly an 840, sometimes a 130Plus, a 530 now and then
A solution that attaches to the bar works best since custom 3d print versions can be made for things like height. Accessories like lights can be mounted with a gopro version
Edge 1050; much easier for me to read in bright sunlight.
Also Garmin Edge 1050 here. I think whatever you’re planning should accommodate the big honking bike computers like the 1050 and the Wahoo Elemnt Ace.
This…Edge 530
Edge 540
Main Screen
Gearing
Time
10s Power
Cadence
HR
