Peeing on the bike + Road cycling shoes/Giro Empires
Hey guys, just in case there is some technique I’m missing here I thought it was a good idea to post this.
For those who are doing their IM bike leg in road cycling shoes (Giro empire for me, they are just too damn comfy), do you have issues with pooling in your shoes?
My last race the drainage on the Empires didn’t really do a whole lot and I was sloshing around for a few KMs.
http://www.londonbicycleworkshop.com/Images/Giro%20Empire%20Shoes%20Black%20-%20Sole.jpg
I drilled several drain holes thru the carbon soles, helped immensely with drainage and ventilation
Here is my approach. It is inspired by watching male dogs piss.
On a flat to slight downhill with minimal spectators, first check that no one is close behind.
  1. Straighten left leg with pedal at bottom of stroke.
  2. Unclip right cleat.
  3. Lift right leg out to side, at 35 degree angle kind of how a dog pisses.
  4. Whip out pecker and aim toward ground at about a 45 degree angle, and toward the side at around a 45 degree angle to bike frame.
  5. Piss with strong flow. Piss stream will loop under your right leg trailing behind you.
I am a MPO rider, so the extra 30 seconds lost doesn’t bother me anywhere near as much as sitting in my piss. Plus, it makes me feel more connected to nature.
your lucky day…
The funniest thread on ST of all time for your pleasure AND education…
https://forum.slowtwitch.com/forum/Slowtwitch_Forums_C1/Triathlon_Forum_F1/I_Pissed_my_Bike_and_I_Liked_It_P3467762
enjoy!
Good lord. This is the best thing I’ve read on here in a while. Thanks.
I think you should be happy it was pooling in your shoes, I hope it was a great reminder to work on your hydration strategy. Which would be the answer to your “problem”, and not drilling holes in your shoes.
But thanks for the great read =)
+1
So much fun reading the entire thread
Condom catheter…that is all…it’s a thing in enduro mtb and enduro off road car racing.
  1. Lift right leg out to side, at 35 degree angle kind of how a dog pisses.
  2. Whip out pecker and aim toward ground at about a 45 degree angle, and toward the side at around a 45 degree angle to bike frame.
  3. Piss with strong flow. Piss stream will loop under your right leg trailing behind you.
If your leg is at 35* and your nozzle is at 45*, don’t you pretty much drench your leg?
And drysuit diving. Have some in the closet in fact but not sure I’m gonna strap one of those puppies on in an IM :stuck_out_tongue:
If you keep your feet at 3 and 9 then it will not all go down one leg, and some will not go down the leg at all
  1. Whip out pecker and aim toward ground at about a 45 degree angle, and toward the side at around a 45 degree angle to bike frame.
Other than doing this would be illegal in most places and against all Triathlon regulations. You cannot whip it out it has to stay in your shorts or you violate the indecency rules.
You’re right. It looks like Ironman handbook rule #666 clearly states: “Athletes shall not whip out their peckers. The public display of a damp pecker, shriveled from lack of blood circulation and covered in Chamois Butter, is is more indecent than soiling yourself.”
alright, here we go. just buy one of these bad boys and have the hose sticking out the leg of your trisuit.
https://www.walmart.com/ip/DMI-Portable-Wearable-Men-s-Urinal-One-Size-Fits-Most/32427477?athcpid=32427477&athpgid=athenaItemPage&athcgid=null&athznid=PWVAV&athieid=v0&athstid=CS002&athguid=466001f5-aef453f5-29da316f8dcbd488&athena=true
