Hi Everyone
Thanks a lot for the questions.
I’ll try and cover off a few here and then make my way down
Apologies if I don’t master the Forum thread / reply nuances right away;
Slowman – Thanks for having us.
As PK pointed out, World Triathlon have over the years developed what is now the recognised gold standard in competition rules. They are used now at the majority of races around the world, including most Challenge and Ironman events. Ironman and Challenge, as well as member federations are now involved regularly in working group discussions led by World Triathlon, whenever the rules need revising, which I feel is a real positive to see.
These event companies have recognised the value in using this very clearly defined rule set, rather than having to come up with and maintaining their own huge legally checked document and processes to achieve largely the same result. It’s a good thing for the sport if we can unify around one standard set of rules. Athletes get a more consistent race experience wherever they are, and the federations who are usually delivering the officiating, have one set of rules to learn, train newcomers on and administer etc.
*“i think IRONMAN (as one example), and each NF, will want to deploy the tech and build the rules of competition using the tech as they see fitâ€. *
Yes it will still absolutely be up to the event companies discretion as to whether they want to offer the technology at their races or not. There is no mandate that RaceRanger or other tech must be used. We would never be able to get enough made for at least a few years… but it’s more that there will need to be some additions to the existing competition rules, to accommodate RaceRanger, to be applied at events where it is in use.
It’s worth noting that most NF’s use either the World Triathlon rules with the odd local variation here and there. Including the setting of the drafting rules and distances. Some events also don’t require penalties to be served on course, but they are just applied at transition or the finish time. The RaceRanger app, which can actually be used as an officiating tool for all level of races without needing the on-bike drafting hardware, has an ‘event creation’ / set-up process, where these options are selected, so the system operates the right way for the event on the day. If you have 2 races on the same course at the same time, subsets of race numbers can be programmed to be with different rule sets. For example if you have a half and a full within one event, they run the same drafting distance rules, but the time penalties are different for each. So different penalty times are pre-programmed for each set of athletes, and then when they get a penalty they serve the right time.
1.* **How much? *As we will deliver the service at the event (like timing companies today) it will most likely be an increase to the entry fees for an event to cover the cost. And obviously event entries open up generally a year out from an event, so there is a good lead time between us having it ready and proven to it actually being used by those larger fields. Unfortunately we can’t put a firm figure on it at this stage for a number of reasons. We have enough components to build a good number of prototypes which will comfortably get us through a couple more development stages, but it is very hard to get an accurate new quote (still was 2-3 weeks ago anyway) for nearly any electronic components right now due to the disruptions to global manufacturing and supply chains. It’s a real mess.
But we know it has to be realistic. It has to be low enough that it doesn’t cause many (if any) to choose not to do a race. We would love to make it free, but you know… investors, 5yrs of effort etc.
After the kinks have been ironed out in delivering the service we see some demand from athletes to buy the devices themselves to practice with in training. It would need to be yourself and a buddy each with a system for it to work, and we would need to make some further software adjustments. But initially we will avoid the hassles of a) packaging, b) consumer sales and collecting $ c) warranties and returns, by retaining ownership of the devices. We can also make sure any bugs are thoroughly sorted out this way. We can test every device before we ever take it to a race. Most electronic goods have a % failure right from manufacture. If a couple of our devices fail from the factory, we can just take them out of circulation before they see the light of day.
*2. **Do you see this is a pro-only device or a device used by the entire field? *
Initially we will definitely get feedback from pros (we’ve been doing this already), and they will be important in helping us validate the tech and gain acceptance that everything works. But from the start we were clear that we didn’t think we could make a pro-only system a viable business, and so it had to be applicable to both groups. There are clear differences between the two. As a business it works either one of two ways; a) the entire field uses it, and we then need to make a lot of devices (3500-4000 sets) to be able to cover them all in a season, but the cost of delivering the service can be quite modest as it’s spread widely.
OR b) we go the way suggested here by others, and it is offered as a way to segment the AG fields at big events. Ie an opt-in at entry for those that want to choose to perhaps qualify for Kona, or be placed in their age group, or similar. The per athlete charge would be higher for this way, again depending on the uptake, but with lower numbers, it would be easier to manage physically as well (handling time). There would need to be a way to keep athletes with RaceRanger separate from those without it, so some more race operations questions to work through around this way.
If the latter, who pays? is this a rental thing?
Correct. Hardware as a service. Initially we will have a team of our own staff that will deliver the service in a controlled way, likely for 1-2 seasons, and yes then move more to selling the systems to others who would provide it to spread it wider around the world, as well as direct sales to riders.
Is there a timer embedded in the device?
Yes correct. The devices only report ‘illegal time’. So once you go over the 25secs, or whatever rule the event set is following (pre-programmed before the race), that timer is started, and that info is sent out for any referees within range to pick up. When the data is picked up by a referee it’s then shared to the cloud part of the app, which determines what to show the referee. We only show them the worst offending handful (they have asked for this). What qualifies you to be one of those handful of ‘worst offenders?’ How do we determine what is bad drafting? Athletes are ranked by their illegal time, in a rolling period, currently this is the last ‘illegal time in the last 15mins’. The referee can then see the location of those athletes and be able to move ahead or drop back to see what is going on or speak with the athlete. Really what the referees do with the info RaceRanger provides them will be up to them to decide. Just like a video replay system in many sports.
We’ve gone quite deep on a lot of the questions you may have, on our website under the FAQ page.
Thanks!
