Hi Eric,
Thi is my first post after being a long team reader on ST. Have been active in tri (up to half distance) until a few years back, then life happened and now finally able to get back into the great sport.
I used to own an old 2nd hand tri bike, which I sold. Since then been riding on a road bike.
Now looking into getting properly set up (again) so planned a bike fit yesterday which led to the following numbers:
PadX: 484 mm
PadY: 651 mm
PadZ (C-C): 210mm
Saddle height: 824mm
Saddle setback (ISM PN 3.0): 28mm // 112 clamp-nose
Extension angle: 15 degrees
Crank arm length: 165 mm
Based on this, could you please advise wether a size 56/L or 58/XL for either a P5D or a P3x/Px series would be the best option?
Based on Cervelo’s geometry tool, it seems that both should work based on X/Y, but I would also like to be ‘future proof’. For example if I would like to upgrade to custom extensions such as Aerocoach Ascalon (which adds 35mm stack).
Another question, regarding crank length. I noticed that Cervelo bikes don’t have the length listed by default. However some research seems to show that 58/XL bike comes with 175mm cranks and 56/L comes with 172.5mm cranks. Given the shortage of parts, i think it’s somewhat realistic that I might not be able to find 165mm cranks on a short notice. How should I adjust my fit coordinates to work with these longrr cranks? I assume lowering the saddle so knee extension angle doesn’t change and then increading PadY to maintain hip angle, or do you have other thoughts on that?
Finally, I seem to notice that the P5D only comes with the EX11 monopost, which cannot get to the 15mm angle. Is this swappable for an EX10 and does an ex10 increase/decrease PadX/Y compared to ex11?
I have included a picture from the bikefit as well for reference.
Thank you very much in advance for your input!
Kind regards, Pim
Hi, thanks for reaching out.
With a Pad Stack of 651mm and a Pad Reach of 484mm you would be either a size L or size XL in the PX. With the size L, your limiter would be that you’d only have 20mm more reach to play with. On the XL, you could only get 30mm lower. I suspect from intuition and hearing some things that the size L would be a couple watts faster and would accommodate the stack height of custom extensions.
In the P5D, you’d be a 58cm for sure, despite fitting ever so slightly on the reach of a 56cm, unless you know you’ll never get longer (a rarity for people who work with me) in which case the 56cm would help accommodate the increased stack height of custom extensions.
As for cranks, the industry is hopelessly behind. Bikes are shipped, and have been shipped since the beginning of time, with cranks that are 10mm too long for TT applications IMO. Also IMO, next to the saddle the cranks are what tie the fit all together so I’d work hard to get a swap done so that you can ride your preferred crank length.
If you go shorter than 165mm, there are better cheaper options so that you can have your cranks and still have a power meter, for example Cobb cranks and Assioma power pedals.
Make sense?
Eric
