Hoping to break 2:50 for marathon
My last attempt to break 2:50 failed.
Tell me why this won’t (or didn’t work last time)
Details:
43 year old triathlete
Been running for 7 years, racing triathlons for 5 years, was collegiate swimmer.
Currently in good shape (just did IM)- hard weeks average - 9 hrs bike, 44 miles running, 16000 yds/swimming.
Poor running speed (probably cannot break 18:20 for 5k).
Good running fitness- ran 1:20 half marathon last year, and had some good 70.3 and Olympic run splits (38, 1:26).
Running plan- 12 weeks
Hard weeks:
2 hrs easy swimming
4 hrs easy cycling
Runs 50 miles
Runs:
  1. long run - 20-24 miles
  2. tempo - 8 miles (half marathon pace + 5 sec)
  3. easy run 10 miles
  4. easy run 6 miles
  5. easy run 6 miles
    I also plan to do 1 long run with hard finish per month).
This plan did not work last time. (Wound up at 2:54).
I think my form is better and my half marathon speed is a little better.
My 5 k speed still sucks.
If you’re a long way out from the marathon maybe some VO2 work would help. That could help make 6:25-6:30 pace more comfortable and a lower percentage of max. Depending on how important the goal is to you, I might even recommend dropping all swim/bike training and adding double run days. Might even be able to squeeze in one more hard run workout per week this way.
I’m in a similar situation. Just ran 3:28 in Kona, which is not a bad pace considering my best standalone 5k is 17:4X, but I need more speed that mileage alone might not give me (or at least not very quickly). Plan of attack is to do lots of VO2 work and mechanics work, so repetitions as short as 200 meters and no more than 1600. Of course, just as important (if not more), I want to ramp up weekly running mileage using easy slow runs most days of the week. Hoping to get consistently around 60-70 miles/week, which if you think about it, is still way less training time than a big week in triathlon (only about 8-9 hours).
Good luck, hope we both gain a little foot speed this winter!
We would probably need more specifics (like, I hope all weeks aren’t that similar especially early in you training).
here are some thoughts:
your long run seems too long, your longest run should most likely be around 20 miles, and most long runs should be 16-18
you aren’t doing enough fast work and/or variety
you could add some things like hills
in general, I’d say its about adding one more short day, cutting your long run down a little and most of all variety, variety, variety including faster speeds up until the last month when you want to get specific training in
There’s no need for 20-24 mile long runs. That’s a recipe for disaster.
Very long runs (16+) also shouldn’t be done every weekend. Every other weekend is better. Alternate between a 16-20 miler with a 10-14 miler.
When training for a marathon, marathon pace running is important. Run 8-12 miles at MP during the week. You’re tempo efforts are good, but don’t neglect the MP runs.
Long Run, MP Run, and Tempo Run (intervals) are the keys to marathon training. On the weeks that you don’t do your 16-20 long run, you can do a track workout (like Yasso 800s) on your tempo day.
My fastest marathon was 6 minutes slower then what you reported (2:54). My gut feeling is that if you want to break 2:50, you need to not swim or bike for 16 weeks before your target marathon. Don’t get caught up in long training runs (15 miles should be enough). Don’t go for high weekly mileage (mid 40’s should be enough). The most important thing is that 3 or 4 times a week you should run your guts out for 8 to 9 miles. Maybe one day a week you could do a track work out, but more importantly you need to bang out one or two half marathons in under 1:20 one and two months before your target marathon. Think less about volume and more about intensity, as you are going to have to be one intense MF to break 2:50. Best of luck at your purist, Tim
Even a 5k isn’t indicative of “speed”.
You should probably add some actual speedwork. See: polarized training. If anyone brings up the cake bullshit then ignore it. Your previous results and your current goals show that you’re a fairly advanced runner and given your lack of “speed” and the fact that the fastest running you do is a tempo run I think it’s called for. Cut out 2 hours of cycling in your hard weeks to give yourself more time and add another easy run, make it just 3 or 4 miles, plus the speedwork.
Breaking 2:50 isn’t all about high mileage, but high mileage is a BIG part of it. A mid-40s week with a long run of 16-20 is hardly running. That’s 5-6mi/day. Sure there are guys that can do it on less, but they’re the exception. He’s got decent HM results so if the low mileage approach was gonna work, it probably would have. Mileage builds the “toughness” in the legs needed to prevent breaking down at mile 20.
Details:
Hard weeks:
2 hrs easy swimming
4 hrs easy cycling
Runs 50 miles
Runs:
  4. easy run 6 miles
  5. easy run 6 miles
In theory, 1:20 half marathon should get you below 2:50. But your raw 5K speed is a bit slow for the goals. How much do you weigh? Your 18 min suggests that you should not break 2:56. How fast can you run a mile? You might be one of those guys with a big engine whose run technique does not match the engine. This shows up at the mile to 5K range where you don’t have the timing and push off force and gait to run faster, and the same lack of run technique at the faster speeds, plays out again at the tail end of the marathon where when you break down, things go to shit. At the half marathon, you’re not at the top end speed for this to show up nor at the the limit of the endurance for the form/technique to limit you…just a hunch…and the bigger you are, the more it will show up at the tail end of the marathon. I’ve seen a number of bigger guys who can run moderately fast half IM and IM run splits who have relatively poor open marathon speed.
If you want to run sub 2:50, then you have to do a lot of running mileage at sub 4 min per K. In reality, this is not far away from your 5K speed, which is around 3:40 per kilometer.
+1
My advice:
-no swimming
-no cycling
-70-80mpw x12 wks
-Macmillan running plans
-20 every Sunday
-14-16 every Wednesday
-tempo every Friday
-occasional intervals substitute for tempo (especially once closer to race)
-Monday/Tuesday/Thursday/Saturday easy, but often up to 10 miles each
-very little at MP. Use Macmillan running calculator, run the tempos, intervals, LRs, and easy runs at those paces. Don’t cheat by going too fast
-three weeks before your race, on the end of a 70-80 mile week, you should be able to do 2 mi warmup, then 17 mi at 6:25-6:30. If you can hit that workout, you will nail it.
-three week taper (15%, 50%, and very little last week)
With your 1:20 fitness, all you need is the mileage to hold a slower pace for the full 26. Some weight loss associated with no swimming/cycling for 12 weeks will help too.
Another thing, he should consider running 2x a day once or twice a week. Great way to bump up mileage in a less risk averse manner. I ramped my mileage up quickly after IMMT this fall by doing doubles. Able to get in a few 10-12mi days with lower stress.
"In theory, 1:20 half marathon should get you below 2:50. But your raw 5K speed is a bit slow for the goals. How much do you weigh? Your 18 min suggests that you should not break 2:56. How fast can you run a mile? You might be one of those guys with a big engine whose run technique does not match the engine. This shows up at the mile to 5K range where you don’t have the timing and push off force and gait to run faster, and the same lack of run technique at the faster speeds, plays out again at the tail end of the marathon where when you break down, things go to shit. At the half marathon, you’re not at the top end speed for this to show up nor at the the limit of the endurance for the form/technique to limit you…just a hunch…and the bigger you are, the more it will show up at the tail end of the marathon. I’ve seen a number of bigger guys who can run moderately fast half IM and IM run splits who have relatively poor open marathon speed.
If you want to run sub 2:50, then you have to do a lot of running mileage at sub 4 min per K. In reality, this is not far away from your 5K speed, which is around 3:40 per kilometer."
This analysis seems pretty good. I have spent time trying to improve run form (but it is still bad).
I am 6’1"- 167. I have a typical swimmers build. Long arms, broad shoulders, big feet, short legs, muscles on back.
I am not even sure that the problem is raw speed exactly.
I was always one of the fastest kids for sprints in PE class.
(Not varsity track and field fast, but not slow either).
The problem definitely is in the 800m to 5k range.
I did do interval training for a number of years 800s, 1000s, 1200s.
This did not seem to work as well as the tempo runs I am currently doing.
There was short time where I tried to both tempo runs and intervals in the same week. (This was perhaps too much training stress).
I think the advice to cut the long runs a little shorter, might free up some training stress to try to do two hard runs per week again.
I’ve rarely seen so much bad running advice compressed into so few posts!
Your problem isn’t 800m - 5k speed, or needing more speed work, or too long of a long run, or running too many miles (LOL). It’s pretty much the opposite of those things, I’d argue.
You aren’t too heavy and have the raw speed (1:20 HM), you just fade as you go long because you don’t have the miles in your legs. Drop the other sports for a bit and increase the miles. Worry about holding race pace, tempos and workouts to improve your threshold speed. Sure, do some fast economy work to hopefully make your running more efficient. But the real wins are going to be the mileage, and time spent around race pace.
Although you are light enough for your height, close to 170 lbs is still 40 lbs more to haul around the course compared to a 130 lbs 2:49 runner. You’ll see that for your IM run splits or half IM splits, guys your size will generally “under achieve” at the full open marathon unless you can shed pounds and do more running at 4 min per kilometer pace. Realistically if you’re going to run 4 min per K for a marathon, it needs to feel “easy enough” to crank it up “at will” for pretty well any run all week. Conversely you will also find that the 130 lbs fast open marathon runner will under achieve at the IM run because of the penalty that tiny guy pays hauling his bike around the course (same size wheels is a bigger percent of his top line watts)
Personally, I think your easiest path is shaving down 10 lbs and doing more speed work rather than a lot more run volume…bigger guys with swim backgrounds with bigger engines just end up getting injured. You won’t get injured doing IM run training because the pace is slower, but if you want to get to pointy end marathon speed, then you need to comfortably run at those speeds often. I would add more plyometrics and skipping.
You mentioned that at shorter sprints you were plenty fast but at 800m to 5000m you fall off. This is because at 400m down, there is a big fast twitch fiber contribution to that speed. Your slow twitch fibers need to be able to take over and provide that good technique and elasticity over the aerobic ranges. It seems they can’t apply enough sustained force for your size, so either you make them more efficient through adaptation, or you lose weight (ideally you do both). Your aerobic engine from swimming is your friend, but at the high end of speed or the high end of endurance, your slow twitch muscle fiber just can’t do the work yet for your weight. Over the internet, this is my 2 cents. Your tempo runs need to have a lot of “over 4 min K and under 4 min K”…the old style fartlek might be your friend.
PS. You have the perfect build for Ironman and half IM, so depending on how important this marathon is, I would not mess around too much…have a look at Kona top 15 the last few years…pretty well all centered around 6 feet 160 lbs. Unfortunately, this is actually not the perfect build for open marathons…if it was all the Kenyans winning Rotterdam and Berlin would be that big, but they are generally 25-40 lbs smaller.
Is anybody going to ask the glaring “pink elephant in the room” question? What has been your typical racing strategy? Very important piece of information that may be the missing piece of the puzzle.
you have run a 2:54,…that is pretty good, your doing things ok.
But split your long run into a double run day. it will help with quicker recovery, pace for both run will be quicker than 1 long run. and your overall week will be better from not been so beat up!
keep the good work…
Unfortunately, good pacing would not have saved previous races.
I have actually run 2:54 twice.
The first time was well pace. I ran 20 miles @ 6:38, 3 @ 6:25 (ok not that part), 3 @ 7:00.
The second was: 16 @ 6:35, 4 @6:30, 6@ 6:50.
I only ran one marathon, 2:47 on a nasty day in Toronto at age 38 and weighed about 160 -163 at 5’10" It being my first marathon, i ran instead of raced it. I was only running then, with twice a day for 3 days a week, one long run of between 17-23 miles (often done at 6:30 pace) We also did a lot of very fast track workouts, probably way too hard.
18:20 for 5K coupled with a 1:20 half at 42-43 is not too shabby at all. Quite good, actually.
In your previous marathons, was there a drop off in the second half?
Fuel issues perhaps?
I suspect it’s not a mental focus issue as you are used to doing Ironmans.
I like tempo runs, they force you to focus.
Whats’s your pace for your long runs?
A couple of people have argued something like this.
A few concerns (probably inane ones).
  1. I am concerned about loosing bike and swim fitness. 12 weeks is not very long. But…
    Any opinions about what the minimum amount of swimming and cycling one might do so that it does not take too long to get back to 70.3 shape?
  2. It seems that easy swim and bikes might be almost as effective as easy runs on recovery days.
  3. I have never been injured. That may be because I am cautious. Going from 45 miles per week max to 70, probably would not be a problem. But in a period of 4-6 weeks?
1)You will lose some swim/bike fitness. For run-heavy training with swim/bike maintenance, I like 1x1h hard swim intervals and 3x1h sweet spot (no FTP) bike workouts per week. You can still fit 60-70mpw on that plan, run wicked fast, and not lose much swim/bike fitness in 12 weeks. I just do the swim/bike workouts on easy run days.
  1. Disagree with the #2 premise. If your goal is to run as fast as possible, you should run as much as possible within reason. Elite runners do not substitute swim/bike for easy days (though they may add them to base run workouts). Now, this is all assuming your goal is to run as fast as possible. Only you can decide whether you want to make the tradeoff of giving up swim/bike for this period. In fact, the monotony of run only training is what brought me to tri.
  2. you might get injured. In my experience, to train properly as a marathoner, you are always on the knife’s edge of injury. Another reason tri is great.
I really don’t think this is very complicated. You have a ton of speed, but your endurance is severely undertrained for a sub-2:50 marathoner. Miles will do the trick.
A 2:54 is close but depending on how your pacing went for that race, you might have a bit to go. Here’s my recommendation for peak weeks:
Monday: Easy 6 miles
Tuesday: 10-12 miles (tempo for middle 6-8 at half marathon pace)
Wednesday: Easy 6
Thursday: 10-12 miles (6min/3min off fartleks at 6 minute pace on terrain similar to your course after a mile warmup with a mile cool down)
Friday: Easy 8-10
Saturday: rest day
Sunday: Long Run day with max of 20 miles
Although at 43 man be wary of injury…I’m 43 and can’t do 2:50 goal marathon work anymore.
Good luck…
