If one were to attempt a critical power test, what would a resonable protocol look like? I’ve read a number of posts here, as well as Eddie Monnier’s paper on Velo-Fit and the section on CP testing in “Training and Racing with a Power meter”. I think I have a reasonable handle on what the power-duration curve means and how to derive it (thanks largely to Eddie’s Excel spreadsheet ;-). What I don’t know is, what is a valid test protocol? I’ve read Dr Coggan’s recommendations that the three durations should be between 3 and 20-30 minutes, so I was thinking of trying 3, 8, and 15 minute tests. Are these reasonable points? How much rest/recovery should be allowed between tests? Is it reasonable to do them all in one session with enough rest between efforts? What sort of warmup is recommended? Is doing this on a trainer with a powermeter (Ergomo) OK (it would certainly help me eliminate many variables like weather, wind, road conditions, etc and make the test more repeatable). Thoughts?
Edit- the next chapter in the book outlines a “Power Profile Test” (pp. 65-66). This protocol sounds like a reasonable approach to me (substituting the CP test durations)… warmup as outlined followed by the three tests in descending order (15 min, 8 min, 3 min) with 5-10 min rest between sets and cooldown. Thoughts?
I’ve discovered a challenge/problem in the sport of triathlon, more specific to IM, when determining one’s FTP. That problem being: There’s too much of a dependence on all-out TTs and not enough on training data (eg mean-maximal). Here’s a paragraph from a current doc I’m writing:
Establishing your FTP is the pragmatic or functional approach to determining power at lactate threshold (LT). It is widely accepted that power at LT is one the most accurate predictors of endurance performance ability. By definition, FTP is the highest power an athlete can maintain in a steady-state (or quasi-steady-state) for a prolonged period of time (i.e., ~1 hour) without fatiguing. There are several well-documented ways of estimating your FTP. However, I believe there are additional factors one must consider when establishing their FTP for IM. Those factors are:
An emphasis on specificity
A de-emphasis on the use of intervals and a greater emphasis using your Mean-Maximal Power (MMP) at >4 hours
Being able to sustain high (relative) power in a reasonably aggressive aero position for 1 hour is one thing. Being able to sustain high (relative) power in a reasonably aggressive aero position for 5+ hours is a completely different challenge. If you haven’t spent an appropriate amount of time doing race-specific preparation training then depending solely on short interval power testing (e.g., 2 x 20 minute) to establish your FTP might lead to some disappointment on race day. Now, when you do test, all of it should be done in your race position. Some people have a tendency to choose the position in which they can produce or sustain the most power for an interval and that’s not necessarily their race position. That’s probably fine for establishing power training levels but your goal for racing is to make sure your FTP is truly reflective of power you can sustain in your race position. What I’ve discovered through my own experience is that the longer you’ve been training and racing with power, the less dependent you need to be on FTP testing.
So, this isn’t so much of an issue when targeting interval power when training but much more of an issue when using a PM to help you appropriately pace the IM bike. However, they’re clearly not mutually exclusive results either, imho. Note that **without fatiguing **is a critical part of the definition of FTP. It is equally critical to see a lack of fatigue as the primary indicator in a declining power profile on the IM bike. My research is pointing to a lack of specificity preparation as the primary cause of that fatigue.
For the computer/networking geeks… I like to refer to it as “TFTP” or Triathlon Functional Threshold Power…
Thanks, Chris
