Cool!
are those 28mm GB5000s? no problems for clearance?
Yeah, 28’s front and back. No issues with clearance although it’s somewhat snug in the rear. I run my rear disc with 28’s as well.
Cool!
Any chance of you making one of these and selling?
Here is my Race Set Up:
What’s the setup you have behind your aero bottle?
It is from a german company called Radsport Ibert.
This is the Cockpit:
Zipp Vuka Bar
Profile Design Stem
Kismet Arm Rests
USE Extensions
Zipp Vuka Bar
Profile Design Stem
Kismet Arm Rests
USE Extensions
Sorry, I meant the downtube storage box and aero bottle.
Zipp Vuka Bar
Profile Design Stem
Kismet Arm Rests
USE Extensions
Sorry, my fault:
Box is from Radsport Ibert from Germany. Bottle is from Elite
Exactly what I’ve been looking to try on my P-Series, thank you.
Same Box on Anne Haugs P5. I think he ships worldwide
I sure hope so, because I just placed an order to Texas.
No worries, happy to. Just drop me a message on IG
@danestanley
Any idea if the aeria hydration system will work with the tririg sigma xf stem? Very similar shape but im not sure how the hydration system mounts to the stem.
I’m looking to clean up the front end of my older P2 a bit.
Thanks!
If you can epoxy the little two screw stem mount to the Sigma stem, then it might work. You can see that pictured here. Unfortunately I don’t know if the shape of the Tririg stem fits in the cutout area of the hydration bottle. I suspect it probably does but there would be some gaps there that might cause it to shake a lot when riding.
What rear hydration are you using? I’m looking for dual setup that does connect to saddle rails.
I’ve got a Di2 P-Series and replaced the cockpit with the 51-Speedshop setup and some TriRig closed back scoops. I love it. It’s very comfortable and easy to adjust, just pay close attention to the length of the bolts you use when installing the spacers. For hydration I just run an XLAB cage BTA with a standard bottle, along with two more attached to my saddle rails. I kept the Cervelo aero bottle and use that for a Gu/water mixture for longer rides or races. Other changes include Rotor 165mm cranks, Kogel ceramic BB and oversized pulley wheels, JCOB Delta 38 saddle, and AeroCoach Zephyr wheels. Here’s a fairly recent picture before I got the TriRig scoops.
https://i.imgur.com/ufon6oD.jpg
what brakes are those? they don’t exactly look like shimano.
thanks!
I got the Profile Design RMP, it’ll support one or two bottles.
thanks!
They are, they’re the one-button hydraulic Dura-Ace levers (ST-R9180)
I finally received my storage box/aero bottle from Radsport. This is much nicer than the rear storage box from Custom Bike Xcessories. The material is MUCH thicker and the build quality is much nicer. There’s a tad bit less room, but it shouldn’t prevent me from being able to carry everything I need. I have no way of knowing which option is more aero (nor do I care), but the box from Radsport is built better and is in a safer location that doesn’t take away from being able to use an aero bottle.
Can you still use the Cervelo aero bottle with that Radsport box? I’d be really interested to see more pics and how much you can fit in it.
I never thought to try the Cervelo aero bottle because I got the Elite Chrono bottle, which is also 500ml and is designed to fit flush against the storage box.
I ordered it for my P Series about a month ago and it only took 2 weeks to get to me in Atlanta. It is a clean setup - you will love it. Heather Jackson has it on her Cervelo as well.
