Best non stick frying pan?
Makes sense.
My colleague has 4 PhDs an Mph and mba so I pretty much believe whatever he says.
quote Rick_pcfl]I assume you know that non-stick frying pans are linked to Alzheimer’s.
Having issues with cheap pans. What’s the best non stick pan?
I did some research after reading your comment. I’m not sure that whatyou said is completely accurate.
. https://www.sciencealert.com/...s-an-expert-explains
Making a statement like ‘I assume you know that non-stick frying pans are linked to Alzheimer’s’ will probably need a little more scientific proof than ‘my colleague has 4 PhDs…’
I agree.
Makes sense.
I agree.
Makes sense.
Alzheimers is for peasants. Fortunately, my dad’s dementia is not from Alzheimers. Wouldn’t want that to impact my inheritance.
I agree.
Makes sense.
I guess I should cut down on my consumption of nonstick pans.
Cooking your nonstick pans in iron might be a bit messy, but, WAY more healthy.
Eating them raw is just, so…
Some good info here:
https://www.theguardian.com/us-news/2024/jan/28/north-carolina-pfas-forever-chemicals-testing
I have 2 sizes of cast iron. I’d consider getting a third, then tossing the rest out.
I use cast iron now. The last set of nonstick I got has a brown coating and they are terrible. Stuff burns oddly on it and the coating is coming off.
I’ve got a 6”, 12” round, a 14” square griddle also.
I did pickup a 10” carbon steel pan that’s awesome bc it heats up fast, and stuff doesn’t stick.
I got this off of a reddit suggestion and I’ve liked this pan a lot.
I recently bought a carbon steel pan. I haven’t used it much yet, but it is great for frying eggs. I got it from Misen.
I may pick up a 14in sq. It will work better for French toast, etc.
We are fans of Scan Pans
scan is good stuff. i would be very happy with scan. beware, tho, you’re now rich apparently.
You certainly won’t be after buying those pans!
