So our bathroom has a toilet paper dispenser and the screw jacketed in a plastic sheath for one side has come out of the wall. I have looked at YouTube but before I do their suggestion I thought I’d ask here.
It’s probably time to move.
Just burn it down.
What was the YouTube suggestion?
I’d probably either move it up or down a couple inches or use a bigger dry wall anchor. And teach the wife to not lean on it so hard.
Self drilling plastic anchors are generally wider than traditional plastic anchors and will drill snuggly into the hole where the previous plastic anchor was.
He, at best will not be able to use TP in this house anymore. Here is a list of alternatives:
https://www.cottonelle.com/en-ca/tips-advice/bathroom-hygiene/toilet-paper-alternatives
Maurice
Toggle bolt.
This. Or a toggle bolt.
You are trolling us, right?
Haven’t you always wanted one of these so you can keep spare TP? You can find them at Home Depot. If you go into the parking lot, you can probably find someone to help you assemble it and load TP into it.
My mortgage rate is too low
Just burn it down.
A big screw looking anchor, a toggle bolt, and using expanding glue.
Can’t move it because it’s a wallpapered wall and it was the child
Yep that was recommended
I’m looking for confirmation or an alternative
Best advice ever was the putty knife when my garage door was frozen to the ground
FTR, this exact task was also on my list. This gave my the reminder to stop by the hardware store. Mission accomplished, worked like a charm if I do say so myself.
You want a cheap and sleazy fix, or do you wanna do it right?
Obviously, sheetrock anchors are not conducive to your household use, so I would recommend doing it right.
What is right? To me, get a board that matches your ‘decor’ - hardwood, pine, painted whatever, kinda depends on what and how you want it to match. Cut it (ha!) At about 18 inches, width to be determined by your preferred aesthetic. Well, presuming the 18 inch width will span two studs next to your shitter.
Then, I’d router some sorta edge to it that would look good. Mount that to the studs so it’s solid, then mount the TP holder to that. Lot’s of ways to make it all look good, fill the screw holes, etc, etc.
Why do you do this to yourself? Are you interested in getting better at this sorta thing, or are you just berated into taking these things on?
- Jeff
- Jeff
I enjoy it
- Jeff
I enjoy it
The berating from your better half?
Or trying to learn?
I’ll probably regret this, but what tools do you actually own?
- Jeff
Does this apparatus mount onto a baseplate which is attached to the wall with the fastener, or directly to the anchor?
- Jeff
I enjoy it
Or trying to learn?
- Jeff
The actual doing part.
I have a well pretty stocked tool box I got as a wedding present.
Garden tools
A power drill. An electric screw driver. Air compressor. Reciprocating saw. Feel like I’m forgetting some things
- Jeff
I enjoy it
Or trying to learn?
- Jeff
Garden tools
Ho boy…
