So what didn’t I set up correctly. My wife is hooked on Zwift. When she records here trainer ride with her 520 plus she gets all the training metrics in GC.
When she rides in Zwift she is turning her 520 off because I setup Zwift to connect to GC - She would get a double entry every time if she used the 520.
She is getting all the data, including heart rate, but the Training Effect is reported as 0 - No Benefit.
training effect only comes through from a garmin device. If you want the training effect to work properly, then have the 520 connect to GC and disable the Zwift feed.
So Training Effect is calculated in the hardware and not the software.
Thanks.
