What I mean, is that the resistance on the Tacx suddenly forces me down to 30-40 RPM. I can keep pushing 280-300w.
What do you mean by the cadence dropped? You mean you dropped your cadence? Or there was an error in how the trainer was measuring cadence?
What you’re describing sounds a lot like what they call the erg spiral of death.
Erg mode helps keep a constant power by constantly adapting the resistance to your cadence. If you lower your cadence, it increases resistance, if you increase your cadence it reduces resistance.
The issue arises if you’re reducing cadence too quickly and/or the power target is too challenging.
It also takes a little paying attention. If, for instance, you’re doing a workout while watching TV, you might easily find yourself grinding at very low cadence.
Shifting gears can also cause issues. It can be very tempting and instinctive to switch gears during a workout but erg mode will keep applying its logic.
Is it possible that you’re using power targets that are beyond what you can actually hold (even if just a little challenging)? Presumably if your previous trainer wasn’t accurate, you’re trying to hold power targets that aren’t feasible for you now that you have a more accurate trainer.
In general, challenging workouts are easier to complete without erg mode.
By the way, trainer difficulty and inclines have no impact on erg mode.
Also, the way the trainer works in erg mode is that the app sends a power target to the trainer and the trainer does its magic. Erg mode functionality is relatively independent of the connection to the app. If the app suddenly loses connection to the trainer, the trainer simply would stay at the last power target received.
Does the above help or do you think it’s an actual issue with your trainer?
