I have a brand new zoot conduit and it is the best fitting wetsuit I have had so far. I am about a 1’50 per 100 swimmer. I was wondering if a prophet would make much difference over the conduit?
I have not ever swam in the Conduit, but currently use a Prophet. There is a difference in the rubber used and the thickness of some of the panels. The prophet is more buoyant and more flexible. The Prophet should also fit even better as i believe their are more individual panels on the Prophet than the Conduit. The Conduit is a good wetsuit and a good value for the price, but the Prophet has many advantages.
Thank you for the information. As noted, I am a pretty average swimmer at best and believe that the right wetsuit can be some money well spent.
You are welcome. As i mentioned, there are differences, but for the level that you swim at, I don’t believe that the extra few hundred dollars is worth it. Like most of us, you probably would be better spent working on swim technique.
Good point. That would do me a lot of good…
and me as well!
