Zipp Vuka R2C shifters (sram/shimano) - BNIB - were dissasembled - cheap
Brand new set of Vuka R2C shifters. These are the crazy aero Zipp version of the normal SRAM Red R2C shifters. These are SRAM/Shimano compatible
Normal retail is $391.
You can have these for $150 obo shipped (in the US) but please read below. More info here: http://www.zipp.com/bars/vukar2c/
Sooo the reason these are so cheap is that they are from a sponsored athlete and when they were being put on he brilliantly took out the bolt that, to quote Zipp:
"should NEVER be removed. Removing the 5mm bolt can cause the shifter to come apart, this will ruin your day. If you
have disassembled the shifter please call Zipp’s technical experts at 1-800-346-2928. They can help you get the shifter
back together. "
In all fairness, when I installed my own R2C shifters I did the same thing and it SUCKED putting them back together, like I wanted to throw them away sucked but I sent them back to Sram and they came back good as new. Anyways, one side needs work but they have never been used, not one shift and include cables and a slightly beat up box.
Lemme know if you have any questions although I think I covered everything here. If you are a weight weenie you can pair these with Zipp’s seriously pimp Vukashift extensions. I had these for before for my Shimano setup but when I switched to Sram I just couldn’t justify it…
Tai
Are these ones for shimano? And which side was taken apart? Waa the right side the one for the rear der taken apart.i need one but will buy both if needed.
