Zipp is rolling out two of the most important wheel lineup-introductions in its three-decade history. For the first time, from our 202 to 808 rim depths, our NSW and Firecrest Disc brake wheels are purpose built for the new era of road riding of wider tires and multi-surfaces:
Disc brake specific rimsDimples to edge of rimWider rim, same weightTubelessIncludes new 303 650b Firecrest Disc brake NSW wheels now available as Disc-Brake and Tubeless
Zipp is proud to expand its NSW lineup to include disc brake wheels featuring a new rim shape and tubeless compatibility:
202 NSW Carbon Clincher Tubeless Disc brake303 NSW Carbon Clincher Tubeless Disc brake 404 NSW Carbon Clincher Tubeless Disc brake 808 NSW Carbon Clincher Tubeless Disc brake http://road.cc/content/tech-news/228489-zipp-launches-8-new-disc-brake-wheels
Clever by Zipp; part of the NSW premium on the calliper wheels is fact it has much better brake track than the normal wheels
On the Disc version, you can still charge the NSW premium but not have to worry about brake track improvement vs normal 404/808 disc
In addition to the Cognition hubs, there were additional details in the molding process that also were more complex. The brake track was obviously the most noticeable, but not the only, thing that added to that complexity. These new wheels share a lot of that additional complex molding development. And also the Impress printing process as opposed to decals.
Tubeless pros: no pinch flats, sealant for stopping minor punctures, can run lower pressures, generally vastly less flats for me over then last 2 years, better RR in certain set-ups
Tubeless cons: less tire/wheel choice, tires may be a bit more expensive, set-up is best with a compressor or one of those trick high volume bike pumps (e.g. Bontrager Flash charger https://www.trekbikes.com/us/en_US/equipment/cycling-accessories/bike-pumps/bontrager-tlr-flash-charger-floor-pump/p/11881/) I usually just have my LBS do it cause I would rather ride than wrench.
Was tubeless in mountain bikes, then my cross bikes and now my road bikes. I run the Bontrager TLR stuff currently, easy set-up and excellent warranty. That Zipp 808 NSW Tubeless looks nice though.
Are you liking disc brakes now? Or do you want to go back to rim brakes?
Love disc brakes. At home, not so much of a big deal because 1) it almost never rains here and 2) the descents I ride most of the time are fairly non-technical. But after racing Norseman in the rain with it’s really fast and technical (by triathlon standards) descents, I’m totally sold on disc-brakes.
I was coming from NSW rims with hydraulic (magura) rim brakes, so the change was less noticeable than it might be for some. But disc brakes still represent a huge upgrade. Especially in the rain. And just ease of adjustment, travel, etc is awesome. They just work. And are easy to work on.
I was actually surprised that no one picked up that I was riding a prototype set of these wheels in one of the pics I posted:
That’s excellent- been rolling Bontrager TLR carbon wheels for 2 race seasons, can’t go back to tubes now.
Doing the same here! Love the wheels as well as the tubeless option. I’m running Schwalbe Pro1’s, what tires are you using?
Also, always wonder what tubeless riders are carrying for flat repair. I haven’t changed much, I’m carrying a tube, Co2, levers, etc. I always just figured if it was bad enough, I’d pull the valve stem and insert the tube. If the tear is wide/long enough, maybe a gel wrapper, etc?
I try this before resorting to the PITA struggle of breaking a bead to put in a tube:
