Zipp Disc Wheel Damaged - What to do
Hi again,
I recently hit my Zipp Disc wheel and created a small (1 inch) gash in the wheel wall. I’m looking to have it fixed but aren’t sure how to proceed. I called Zipp and got told to bring it to my local bike shop (as I’m Canadian). I am not the original owner of the wheel, so I don’t have a receipt for it’s original purchase (obviously). I’m also not sure where I should bring it exactly…
Would trying to find a local Carbon Fiber expert work in my favor? I’m kind of scared that if I send the wheel in they’ll charge me hundreds of dollars for the repair…
Any advice?
I’m from Ottawa, Ontario.
Thanks!
Can you post a picture of the damage?
If it’s a relatively small/shallow nick I’d just seal it up with some 2-part epoxy to prevent moisture from getting in. If it’s deeper I guess it could be a structural issue but you didn’t seem to suggest it was anything too significant.
This is what it looks like…
Cause for concern?
Nope.
So don’t even touch it at all?
You could put some packing tape over it.
You could hit it with epoxy, which is the same thing Zipp would do (from an ex zipp buddy)
Cause for concern?
No concern there. I’d just seal it up and with a bit of epoxy.
Same thing happened to mine (Super9 clincher disc) via shipping in a poorly packed box (axle of another wheel punctured the disc twice).
I put a valve cover sticker over the area and have raced on it for 2 Summers, no issues at all, no spreading, wheel is perfect true.
http://i65.tinypic.com/2daj61j.jpg
Happens to discs all the time - just put taper over it or seal it with epoxy. It will have zero negative impact on the wheel.
I had a hole in a Zipp 900 & sent it back to Zipp. They slapped something black resin on it & “sort of sanded it down” a bit. Sloppy job repair IMO, but it isn’t even flat like the rest of the disc, but a bump. You’re not going to notice anything performance wise unless you’re in Tony Martin’s class, that will affect you.
