I have a Cervelo R3 Team Edition Road Cycle. I think it’s a 2012 or 2013 model with Fulcrum Racing T wheels. The bike seems to climb very well, but it lacks the roll speed on flats and downhill. I am on the lighter side (135lbs), but I am looking for something that gives the bike more roll speed but I don’t want to lose anything on climb. I don’t know a lot about the Fulcrum wheels, but is it worth the upgrade to grab the Zipp 202’s or another wheel that will give me more roll speed but still be great on climbs?
AFAIK, those Racing Ts are similar to a Racing 7 wheel.
If I wanted to improve my “roll”, I’d first make sure my tires were rated well for CRR, and I’d make sure I had latex tubes. Then I’d make sure I didn’t have any low hanging aero fruit, like a baggy jersey or a bad helmet.
I have '12 Cervelo R3 and use '12 Zipp 202 tubulars and love them. For me (125 lbs), they’ve been great ‘all-around’ race wheels. (Of course, they especially shine on sustained climbs and hilly/rolling courses).
Anyone have any experience with these or advice?
I have the same bike and slap some Oval Concept 932 tubulars on from time to time. It’s really light in that configuration but . . . . I live in Louisiana where the HIGHEST point is around 530 ft above sea level so I can’t speak for climbing.
…or the Fulcrum wheels, which aren’t very aero at all (sharp-edged box section, so similar to Mavic Ksyriums).
If Zipps are in your budget, and you’re looking for a noticeable boost in performance on the flats whilst still climbing well, then have a look at the 303s as opposed to the 202s
They are a bit more of an all rounder wheel than the 202s are.
I’m using Corima Aero+ MCC wheels for hilly road racing, hill climbs, etc.
They’re 48mm deep, but lighter than Zipp 202s. It’s a great wheel… fast, light, good looking.
They also handle really well in nasty wind.
I highly recommend them, especially with a good quality tub (I’m rolling Veloflex, but anything good quality with latex tubes will work).
I don’t see the point in buying a set of zipp 202s/303s for $3000 when you can buy a set of flo 30s that weigh ~50grams more and have an aluminum brake track for $600 ? You could build a set of sub 1300 gram clincher wheels on kinlin rims for probably $1000. Go check out the weightweenie forum for ideas on lightweight wheel builds.
2011 vintage (yes, they need a warranty swap, and no, not 11 speed compatible) 303 tubulars are the way to go. Mine was 1170g for the set before the hub warranty. It really bulges out to ~ 28mm at the widest point, making it quite close in shape to a firecrest.
A set of Flo 30 weigh over a pound more than tubular 202s or the Corima rims I ride. (Both the Zipps and the Corimas are sub-1100g). The Flo 30 is 30mm deep, the 202 is 32mm and the Corima Aero+ rim is ~48mm deep.
I’m sure the Flo 30 are a fine wheelset, but they compete on value. You may not see the point in the more expensive wheels, but a lot of folks do.
I should clarify and say I don’t see the point in Zipp clinchers for the price if you are looking at saving weight. I assumed the OP was looking for clinchers. If your primary goal is to save weight there are a ton of tubular sets is the 1100g range and that is what you should be looking at.
This.
I have a 2012 R3 team as well, with American Classic 58 clinchers I bought a couple years ago. They’ve been great for me so far, but are probably too heavy for what the OP is looking for.
Not to be a total nit picker… but our FLO 30 wheel sets are $498 total.
Love my 404’s but 202’s don’t make a whole lot of sense to me. You can build up a set of similar depth aluminum wheels (Kinlin 31t for example) with lightweight hubs for less than half the cost and get a better brake track and spend a lot less on brake pads.
As far as training on tubular wheels I won’t get into that can of worms but just say this is ST not weight weenies…
