Looking at replacing my current shirts/shorts/hats for warm and hot weather running. I have some older Sugoi stuff that has been fine but lately in the 90 degree temps with dew points in the mid 70s it gets and stays sweaty. Wanting to replace with some more recent gear to do some longer runs in the heat.
What are your favorite warm and hot weather run wear items? So many choices and price points hoping people can give some recommendations on brands/products they like.
IME it doesn’t make much of a difference between items in regards to anything other than chafing and riding up. If old shorts get soaked, so will high end new ones.
That said a pair of shorts with a good liner can make all the difference. I use Lululemon pace breaker and brooks Sherpa 2 in 1 but the sherpas so ride up when drenched.
My current fav combo is a pair of 2XU compression shorts with any pair of shorts overtop. No chafing, riding up and almost forget I’m soaked.
Castelli Summer Headband. Wicks/Distributes sweat rally well so that it helps with cooling and doesn’t run into my eyes. I have tried other headbands (headsweats, halo, decente, etc.) and they all made my forehead feel too hot; not the case with the Castelli.
Oakley EVZero sunglasses. The open frame design has better ventilation than my framed Oakleys (Jawbones, Scalpel). Super light as well.
compression shorts and cheap shorts. If it’s really hot, 80+, I don’t like the heat, I start with my tech short-sleeve shirt wet, which makes me almost cold. This will last for a mile or so making the beginning bearable. If it’s really hot and not too humid, I wear a long loose compression shirt, Target has some Champion ones, and a camelback with ice water. I’ll start with a wet shirt and wet it and my nether regions as needed. Same with hat, headsweats. I always wear a hat for skin cancer reasons. To keep sweat out of my eyes, the hat helps, but I sweat a lot. Put vasaline or chapstick in your eyebrows, the full length of them. This seems to divert most of the sweat around the eyes.
good luck, I wish I could get out more. Report back what you tried and what worked or didn’t.
Barry
Check out Janji. I have a singlet, a pair of 5", and 3" split shorts and they are super thin. Def my go to when its humid AF here in NC. . .which is all day, everyday.
Big fan of Tracksmith gear, although since its pricey I’ve been pretty selective about what I’ve purchased.
Shorts: Tracksmith Twilight splits or the TS Relays I have. Sessions are good too, but can get a little heavier once you’ve sweat a lot.
Tops: Brooks Stealth top, New Balance Ice 2.0 SS, TS Van Cortlandt singlets, or Shirtless. Hoping to pick up a TS twilight tank at some point but I just got a bunch of new running shirts.
I’ve found a headband helpful for keeping sweat out of the eyes, I’ve been using a buff as a combo mask/headband depending on where I am running, but hats from Headsweats are also nice for this purpose.
I’m in Miami, FL. Most of the runs, this time fo the year the weather is Feels Like +95F…and humidity +85%
I run with CEP Compression Shorts; shirtless; Kayano Socks and Visor.
And I always carry my 18oz Handheld water bottle.
With this, I can run +13 miles “comfortable wet”
A couple of years ago I did a hilly double marathon (Ultra 520k) where the temps rose over 35c/95f for at least the second half of the race. To reduce sun exposure over that length of time I chose to run in the long sleeved Desoto Skincooler shirt with Roka running shorts, Swiftwick socks, Hokas and a Desoto Skincooler running hat. Conceptually the long sleeved version of the shirt took a bit of getting used to but it helped keep the sun off me and I was genuinely cool for the run. Some other folks will run that race without a shirt but in my opinion that’s a long time to be exposed to the sun especially if you don’t have complete sunscreen coverage all of the time. Plus, you know, skin cancer.
Shorter runs are less critical of course and I’ll often just throw on an old dri-fit race shirt with light running shorts.
The only thing I do when it’s hot is body glide or some other anti-chafe product. Possibly ditch the shirt but I don’t find that does anything other than give me a tan/burn and my shorts get wet faster (no shirt to absorb sweat). I almost prefer the shirt since it stays wet and I have something to wipe my face with.
Probably a poor choice, but works OK for me. I’ll wear old bike bib shorts (not bib) under my light run shorts. They’re skintight so I’m not running in nasty cotton boxers under my shorts.
That’s about the same as compression shorts. I do pretty much all my brick runs in cycling shorts. The only thing I don’t like about pure cycling gear is that the pad is generally quite a bit larger and thicker than a tri-specific pad. So, you end up with more material “down there”. It doesn’t bother me for less than 6 miles, but after that I’d rather have a tri-pad, or none at all.
IIRC you only run a few short runs a week, mostly for variety…seems fine to me.
Tracksmith Twilight shorts, expensive but by far the nicest hot weather shorts I’ve owned. I really like Swiftwick Aspire socks too, lightweight and don’t absorb any sweat.
+1 on the SwiftWick Aspires.
I just ordered enough pairs that they are all I use for biking/running. The rest of my tech socks are just sitting in the drawer now (with the exception of my SockGuy Evel Knievel socks that came out for the 4th of July).
