el gato - valve cores are removable and are the ultra-premium SILCA ones which produced using roll-formed threads and fully machined critical features
J7 - The valve shields are only included with tubes sold with extensions.  The shields save 0.2-0.5 watts of combined translational and rotational drag and also eliminate rattling and seal the valve hole
pun_times - there are 2 issues with this.  One, the minimum quantities per valve stem length are quite high as the valve stems are applied/bonded by machine which has long/expensive setup times and often times tooling related to each length.  So if we have to buy say 10,000 per size to justify the machine setup time, and we wanted to offer 3 sizes… there is no way we can afford to build and hold all that inventory, not to mention that prices would have to go up across the board to offset inventory holding costs, etc…
Second, the main reason that valves and extenders can be such a hassle is that they are generally made in the cheapest way possible, by extruding a tube and doing some minimal machining on it… this allows affordable 90 and 110mm valves to be made, but they have poor durability, have been known to rupture at high pressures over time, and the seam in the tube from the extrusion process can sometimes leave a slight flaw inside the tube which keeps the valve or extender from sealing properly…the flexibility of the tube wall also affects the machining quality and size control, I could go on about this…
We machine our valves and extensions from bar stock, which solves all of these issues but puts our maximum length of extension at about 70mm due to the depth of drilling the small internal hole, but it also guarantees a perfect match between sealing surfaces.  Since the surfaces perfectly match (AND we use a special domed compression seal) our extenders and tube seal perfectly every time… no tape or any of that necessary, they just work…
So when you have valve extenders that just work, then it now also makes sense for the end user (or bike shop) to not have to carry as much about their inventory either… so you can have 2 tubes and some extenders at home and be able to service numerous depths of wheel…etc.
Long story short, we are confident that if you use our system, you’ll never give valve extenders another thought, and in that world, a single tube gives you the most flexibility at the point of use.
