I have bought the favero assioma duo pedals. So I’m now installing the xpedo cleats and I can’t find the markings that shows the axle position like you have on the look and Shimano cleats. Does anybody know how it looks like on the xpedo cleats?
I’ve done there conversion - almost 18 months ago. I’ve also taken them apart a few times (including just yesterday) to regrease the spindles. Having said that, I’m not clear what you’re asking. I simply take them apart, lay the pieces on a clean cloth in the order that they come off, clean, regrease, and put everything back together.
FWIW - I’ve found that Look Keo cleats work better with the Assiomas than the included Xpedo cleats, much less off axis movement. So, if you have those I’d just keep using them.
I agree. I use the gray cleats and they work great. Also more readily available.
