Any have this yet? http://www.xlab-usa.com/products/rear-carriers/delta-wing.html
Seems like a good solution to keeping a single bottle in the back. Looks like it will keep it close and be sturdy. Not sure about the co2 adapters though.
I’m interested… wonder if it will fit the ISM Adamo seat.
I’ve had good luck with X-Lab stuff, so it seems like a nice option. Tacx also makes something similar, and it’s pretty affordable:
http://trisports.com/tasacl.html
Or, there’s always zip ties.
Nearly as cost efficient as the Torpedo. Buy zipties people.
Worst case, go buy the Tacx mount for $10.
What cage works well zip tied to the back of the seat? I haven’t found one yet. Suggestions?
Xlab gorilla works fine. 2 zip ties.
Tried using zip ties… not the best solution for the Adamo saddle.
Or the Cobb, feels sketchy and has some give side to side.
+1
Between my Adamo and Cervelo seat post my options are kind of limited for a simple solution if I want a single bottle mounted in a relatively horizontal position.
I found one product that works but its very expensive. I’m not paying $80 dollars to have a single bottle behind my seat. I wonder if I can design one with a 3D printer. Hmmmm…
So has anyone tried this with an Adamo yet?
Talked to X-Lab… doesn’t work.
Just found their Twitter post about it:
Unfortunately Delta Wings aren’t compatible with Adamo. All our other carriers are compatible however
Yep, just found this out the hard way. Going to have to figure out a solution. I have an adamo road and a Delta wing. I may try to modify it. What about the Cobb saddle??
I wonder about Cobb’s as well. Anyone know?
Yes it will work with Cobb saddles. The saddle we used to test was a V-Flow Plus.
Candice - XLAB
Thanks, Candice. Order on the way.
any works for an adapter for Adamos?
XLAB likes to cover the market and make sure our customer’s needs are met, so watch this space
An update to this response there are some Adamos that will work with the Delta Wing. The following are compatible: Breakaway, Podium, and Prologue. The saddles that have the transition hook will not work.
