“Apply something like Rex Blue, let it cool, then scrape. Repeat. Repeat again if you want.”
So putting on Blue, scraping and putting on more Blue is preferrable? Better performance? Longer lasting? I’m lazy, so I’m always looking to cut corners. If one coat can do it, I’ll only put on one coat.
“Go ski.”
If only it were as easy as pumping up bike tires.
Thanks
You can put as many coats as you want, but one is all you need :). In your current situation, you’re probably set since your skis have been hot boxed, unless you care to apply a wax appropriate for your temperature first (which I’d do, but since you claim looking for the easy way… you’re set and your bases are gorged with wax).
What you basically want when waxing is a three step process: 1/ open up the pores in the ski bases so you can soak them with wax (this is done by brushing with a reasonably stiff brush, e.g. nylon/copper); 2/ do said wax soaking (meaning going multiple times over the base of skis, tip to tail, melting and remelting the wax you dripped off); 3/ scrape surface wax off the ski and brush/buff/polish (this is done with a soft brush, e.g. horsehair).
Depending on how “thirsty” your bases are, you may have to do more than one coat.
So as a “lazy” guy, you can:
- Do a wax regularly often.
- Do more work less often.
I like doing the wax regularly often and I ski often. I don’t look forward to the mess of scrapped off wax, but I sure like how fast I am on skis!
Something else that I do every time is a hot scrape: take some cheap soft wax (Swix will sell a specific wax for base cleaning, but whatever your preference’s softest wax is great), drip and iron. When the wax cools off on the ski, but before it hardens up, scrape it off. This will lift all the dirt and grime from your bases. Repeat this until the wax you scrape off is clean.
Then wax.
Then ski hard: you deserved it.
