WTB: Specialized S-Works Crank Tool
Anyone have one of these laying around? The threaded pedal insert is working its way loose on my nondrive side crank arm so I need to replace. Never realized before today that I needed a specific tool to remove the crankset from my 2014 shiv. And no I’m not handy enough to weld my own t45 torx bit on a socket :slight_smile: and was hoping to not have to pay the >$40 I currently see on eBay. If you happen to have a left (non drive side) 172.5 s-works carbon crank arm, I’ll gladly buy that too, but figured I’d have to resort to buying a full replacement crankset from eBay.
Edit: LBSs ended up giving me one after they located a few extra. So I’m all set now. Thanks for the replies
There are other options on ebay that aren’t so pricey
and amazon
https://www.amazon.com/T45-Torx-Socket-Drive-Industrial/dp/B0CHWMH5MM?th=1
Thanks. I did find those and reached out to specialized upon discovery. I sent them the link to the ‘gear wrench’ version and they said it would most likely not work as the tiny bit of additional tolerance beyond the bit diameter would lead to it not fitting. I went to my local specialized dealer and they couldnt say if it would work - and they only had a few of the tool - so they weren’t willing to sell. So I’ll likely just pay them to swap these crank arms and then buy the cheap version to see if it fits in the event I need to tinker again down the road.
Hi there!
Just seeing this now, but I have a 172.5 Sworks crankset that’s available if you’re still looking. It’s pretty scratched up, but, if you’re just looking for the bolt/etc then it should be fine. I’ll never use it, so I’m happy to send it to you if you cover shipping.
Just let me know.
