I need a tri frame or bike in a hurry after finding a cracked steerer in my rig and then the replacement bike frame I ordered a month ago not actually being available. Preferably in the IL/WI (or nearby IA/MN/IN/MI) area so I can see it in person and inspect, but open to other areas if you’re okay with a shop doing an inspection at my cost.
Typically the right size is going to be a 58, but some 56 frames like Quintana Roo or Felt IA will work.
Some examples would be:
Felt IA size 56 or 58
Cervelo P2/P3 size 58
TriRig Omni size Large
Dimond size IV or V
Specialized Shiv size Large
Needs: 540 stack minimum, reach preferably 430-440 range, but as low as 420 could work. Must clear a 28 mm tire.
Wants: BB30 (called OSBB if you have a Specialized), PF30, or BSA so I can use my current cranks and power meter.
Would consider a full build or even a disc brake bike if the price is right.
If you send me your email or phone number via PM I’ll reach out ASAP.
