I am looking to buy a Felt Bayonet stem system. For 700c wheels. For size 58 or larger frame. I need the steerer tube to be 150mm or longer. Whatcha’ got?
I have a felt bayonet 2 fork I just found in my spare parts pile. Includes all the stems and bearings.
PM me is interested with offer.
the bayonets are size specific to felt frames, ie you are not going to cut to fit
Thanks jeffP! The head tube on my Softride is 150mm. So, I need a Felt Bayonet fork system that has a 150mm steerer tube.
If you’re not set on the bayonet I have the Felt aero fork I used last season when I replaced my bayonet system. I ride a 56 and there was at least space for 2 cms of spacers and top cap. Let me know of you’re interested.
The fork is from a 58cm Felt B2Pro.
If anyone has a Felt Bayonet fork for a size 56 Felt frame, I’m game.
Pics of said fork and hardware. Sorry for the quality. iPad 2. All in perfect working order.
I know it’s not bayonet but I have the Felt aero fork that I used for my 56 B2 last year. Not sure if you’d be interested in that. If so let me know.
Thanks, but I am looking specifically for the Bayonet fork.
Ok. Figured I would throw it out anyway. Good luck on the search! I tried unsuccessfully used and didn’t want to spend the cash for new. “Thankfully” my FD cable guide thing broke so I got a replacement frame/fork.
not only length dependent, i believe the bayonets are 1" headtube size, even thought the metal steer axis is much smaller in diameter
could be hazy memory
Im interested in the stems, will they it on a Felt Bayonet SL. (Felt B2 pro 2009). Im looking for stems with 31.8 clamp size?
are parts still available?
