Got the pole clamps. I’m still looking for risers.
I’m not sure what angle I want my stock baseball allows for 0, 5, 10, 15. I’d like adjustable risers to try more angles and fine tune something between 15 and 25 1 deg at a time. I’m hoping to achieve that with adjustable ankle risers
You do have the ability to change extensions that will offer a different angle such as the PD asc 53.
Personally the wattshop are an engineering masterpiece but every time to adjust angle of 1 degree or even 5 degrees is a major hassle. Arm pads off, the bolts undone, long 3mm Allen key to pop off the tilt bridge. Once tilt bridge is off you can play with adjustment screw. Set it.
Put it all together to spec torque easily 45 min-60 minutes every time.
I have these and with a combo of the asc 53s I was able to find my ideal comfortable position. Hopefully these aren’t coming off this season.
