WTB: 165mm Crank Arms
I have a 2012 Cervelo P2 with 170mm Gossamer crankset 52/36.
I’m looking for 165mm arms, but I’m not sure about compatibility. Will any crank arms work or does it need to be compatible with my bottom bracket?
If you are willing to swap BBs, almost any 24 mm spindle cranks will work.
If you aren’t, only Rotor and Shimano make cranks with spindles compatible with your current BB.
Also note that most cranksets don’t have standalone crankarms, as the drive-side crankarms are often integrated with the respective spider. Rotor is an exception to this, as are cranks modified for SRM power meters.
Not sure, but I thought I had some, but will check and look at the size.
I have a few 165mm crankset available:
-Sram Apex GPX
-Rotor Aldhu BB30
-Rotor Flow BB30
SOLD I have a 165mm Force22 110BCD (50/34t currently installed) gxp crank that needs a home.
Do you still have the 165mm Flow?
Yes I still have those cranksets available
Do you still have either rotor crank available?
Thanks 🙏
Yes, the Rotor cranksets are still available
Is that a 24mm? Would it fit on a Giant Revolt?
Cheers
Jake
The Rotor cranks I have are BB30, so you’ll need to get another size bottom bracket if your frame is compatible.
What do you want for the Aldhu arms?
