My IMFL ride file got a little screwy when the volunteer hit start in T2. I want the file in Garmin Connect, but it wouldn’t initially import for some weird reason. WKO+ imported the ride file just fine, and I managed to clean it up, trimming off all the dead space at the end. (which cannot be done in GC)
The problem is that I now can’t export it into a format that works right with Garmin Connect. Well, I can export it as a GPX, but the heart rate data is gone.
So WKO+ supports exporting it as:
.wko, .csv (powertap format), .hrm (polar), .txt (SRM format - no heart rate), .pwx, or .gpx (no heart rate)
And Garmin Connect supports importing as:
.tcx, .gpx, or .fit
So I’ve been trying to convert between multiple formats, and every time, Garmin Connect just won’t accept what I try to feed it. I’ve tried various online tools.
Does anyone have any ideas on how I could get this thing from WKO+ and into Garmin Connect with all the data fields?
I would try golden cheetah, or how about Training peaks to Garmin connect transfer ?
Ooh, Golden Cheetah is a pretty good idea. I actually tried Training Peaks, but I couldn’t download it in a different format from what I uploaded it as. But I managed to get it working using the PWX, so crisis averted. Thanks for the input.
I use fitfilerepair tool, saves swapping to different file formats
Are you talking about http://garmin.kiesewetter.nl/ ? I tried it multiple times, and could not get it to work no matter what I tried. The resulting file would never get accepted by GC.
you can send me your file if you want and i can edit it for you
Neil
Thanks Neil. If I come across something major in the future I might ping you. I’ve always been able to fix it by tweaking the xml from TCX files, but this particular file was being a beast.
I tried GoldenCheetah just for fun to see if it would work and Garmin Connect came up with the ‘unidentified’ error after uploading. The http://www.pwx2gpx.com/ website worked fine. Thanks to both of you.
Hi Andrew,
I’m a little slow, what did you try?
GoldenCheetah doesn’t support upload to GarminConnect but can read WKO+ and write TCX.
Did the generated TCX get rejected by Garmin Connect ?
