Winter Cycling Boots
Looking for some recommendations.
Spending $250-$350 for 45NRTH boots seems pretty stupid expensive. I’m hoping for $100-$150 tops. Any recommendations? Lowest temps I’d be riding in is in the teens or twenties.
Also to add, this is my first winter riding, not sure if this will continue, wife already thinks the fat bike was a bad purchase.
You can get some nice winter boots from Sorel that are gaiter-high and well within that budget. Check out the Blizzard, Bear, or Alpha Pac. If you are riding platform pedals in the winter then these are great for those temps.
But the Red Wing 45 NRTH boots look amazing…
For my Fatbike I went with Lake MXZ303-X Wide Winter Bike Boots, still pretty expensive at $250. You could always just use Neoprene overshoes, which is a cheaper option($50).
Are neoprene covers just as warm? I have some and my feet still get cold at 30 degrees or so, granted im not wearing super thick socks.
how cold does it get, are you riding for under 1hr? For $100-150, you’re probably limited to winter hiking boots and flat pedals. If it’s not too cold (down to -7C or -10C), you could get by with winter shoes from most companies, otherwise you’ll have to look more “boot like” options from Bontrager, 45nrth, or Garneau. The fleece lined or neoprene shoe covers can also get you down to -7C or -10C, but you have to put up with sometimes having to “fix” the toe of the bootie in place if it comes off while you walk.
Whats this Celsius stuff? I leave north so -10 or -12 is pretty common. What is probably worse is the wind, 15-25mph winds are pretty normal.
I can’t remember the last time I have ridden flat pedals beyond around the block with a kid. I can’t see myself going that route, but I might have to.
We’re talking bike shoes right?
I had the old specialized defroster and it was cheap but the ankle covereage wasn’t high enough. The new model seems to remedy that.
Currently I’m riding Siri diablos which are pretty great but I generally don’t ride below freezing. Plenty of room for wool socks.
Lake 303s are absurdly warm and can been found on sale with some looking.
Many people (myself included) use flat pedals for the fat bike. Doing that, you won’t be limited to something so expensive - I ride in an older pair of Keen winter boots that have a very flexible ankle/upper.
Thing is, if you plan to be doing this for a while, those boots are going to last pretty much forever. The neoprene covers last 1-2 years depending on how much walking you do…you can extend it to 4 years with creative use of duct tape once the toe starts to wear out. If you get the boots, every time one of your buddies with the shoe covers gets frozen toes you can tell them “at least you saved some $$”.
I ride down into the single digits and have an ancient pair of the Lake MXZ 300s…probably 15 years old. I brought them to a shoe repair place because the heel was coming off. I put neoprene shoe covers over them permanently since I had a pair kicking around and if the conditions are boot worthy, nobody has ever said “my feet are too hot.” I added some duct tape wraps to the toe to protect the part that goes around the cleat.
Make sure you start the ride with warm shoes.
I got a set of Louis Garneau (LG) size 47’s on sale for like $95 5 years ago.
It’s basically a cycling shoe with an integrated center zip cover to form a boot. They are great! I have them on right now, just done cycling back from the plant. Using Crank Bros- type pedals. Took off the flat pedals because I wanted to put more coal on the drive-line!
I spray waterproof them every year. I was looking for another set actually, found these but have not ordered…
<https://garneau.com/ca/en/glacier-rd-cycling-shoes-c
I’ve used both Lake and 45NRTH, but they come at a price.
The new Fizik Artica X5 caught my eye as something that I might use for crossover seasons here (even that R5 road version would be useful for half our riding season). Not as heavy duty as the Lake/45NRTH options, but probably fine for your riding temps. You can always go a couple sizes larger to allow sock layers, vapor barrier options or electric socks/insoles for very cold days. The $200 price seems reasonable, though a bit over your price cap.
Are you comfortable in those LGs down to ~20?
I use some MTB Northwave boots, picked them up in the sale for ~$100 a couple of years ago. Fine down to the low teens in Fahrenheit even for pretty long rides, where I live that’s about as cold as it gets. I prefer two-sided MTB pedals for riding in winter anyway, easier to clip in and out with gunk on the cleats and pedals, and with recessed cleats it’s easier to walk around on wet or icy ground. The only time I had an issue with them was when I had a ride where I got unexpectedly soaked with rain and got wet feet, then the temperature plummeted well below freezing. Normally if there’s rain expected and it’s cold I’ll wear some waterproof overtrousers, since the one problem with fully taped, waterproof boots is that if water gets in the top there’s nowhere for it to get out again!
Good thing about winter boots is there are always some good deals in spring, though I appreciate that may not help given that it’s early December…
Leave plenty of room for nice warm merino socks.
What kdw said - a good quality cycling boot will last many seasons. This is not an area you should skimp on if you are planning to enjoy winter cycling. I do a lot of cold fatbiking up here in Quebec and depending on the temps I’ll use either my 45N Fasterkatts or my 45N Wolvenhammers. The Fasterkatts can take me from 0 to -10 cel. and the Wolvenahammers from -5 to -20 cel.
I also use backcountry snow pants with suspenders that cover my boots. Warm legs = warm feet.
Edit: Both boots are purchased a little bigger to fit thicker wool socks.
I found the 45nth boots to be pretty lacking in quality and consistency. Even right to left the sizing is wonky on some pairs.
Those things are definitely priced to market, QBP has about as much expertise in making a shoe as they do in making a bike.
Just bought a pair of Sidi Frost Gore from one of the German online retailers.
A bit over your budget, but I bet they last a lifetime.
Probably not the warmest boot for sub-arctic fat biking, but plenty warm enough for me up to -10C or so.
Any colder than that and I wouldn’t be cycling anyways.
All of the hardcore fat bikers are riding 45Nrth. I’ve heard the Bontrager boots are pretty good to.
This. I tried going cheap for years, until I finally bit the bullet and invested in some Sidis w/ the Gore-Tex liners (where I live, wet is a much or more of a problem than just straight arctic cold). The various booties kinda sorta work situationally, but I was always struggling w/ some other trade-off (my shoes are big enough it was hard to find the right size that wasn’t so tight to squeeze circulation and wrestle on/off, but not too loose so that all kinds of shit seeped in, and they also rubbed the crap out of the crankarms). When I ultimately got the dedicated cold/wet-specific cycling boots, I only had to make the painful trade-off of cash once up front and have never second-guessed it since.
I’ll add that the MSRP made me cringe, but after having my eye on them for long enough I was able to find my size in the previous color/style off eBay for a little over half (i think they had an older version sole too instead of the very latest super-duper ultra carbon $$$ whatever; hardly a big deal for this application).
Although that’s of course not as helpful if you want a new pair immediately and they haven’t updated model cycles recently enough.
Until now I used neoprene covers from specialized, worked but feet got cold soon.
Decided to get winter boots last month and went with NW Flash Arctic gtx.
Been described to insulate til -10 degrees Celsius, my feet got cold after 50 mins at just 1 degrees. When the ride was done at little over 2 hrs they were frozen.
I did send em back today and see if I get the refund of little over $ 220 although I used em, which is the only way to find out if they work.
Liked them other than that a lot.
