I’m going to the windtunnel for the second time looking for some answer.
I would like to determine which bike between my slice black and my P3 could the best choice for me for Kona this year.
I have exactly (almost exactly…) the same position on the two bikes.
I was wondering to test first the slice with his old easton attack front end then to switch the front end with the one of the P3 (3T brezza Ltd) (I would have removed all the cable to let just fake cable sheath in place like the last time… it works perfectly).
Then I will put the P3 with the the easton and after that with the 3T (last time I already change the aerobar it took less than 2’).
BUT if I will test at 40km/h, 180w I’m not sure about the yaw angle… Last time we test only 10° for the all session. What could be the most representativ yaw angle(s) for me (between 5h15-5h30 depends on the wind in Kona) to see if there is a difference between the two bikes… Please let me know your mind…
I will test some aerosuit with 2 riders 40km/h, 180w, 10° (Zerod TTsuit, Compressport, Castelli Stealth T1, Bioracer, Zoot aerosuit, Virklon)
I will test some helmets with 2 heads position same datas (Wing57, Bambino, Sworks TT, Speedairo)
Just stumbled across this thread looking for some data on the sleeved tops… I have a Virklon half sleeve top and I’m thinking about wearing that over a sleeveless tri suit during the bike. Do you think there are significant aero benefits to these tops? Worth the extra layers in the heat vs. sun protection, etc?
I was in Magny Cours (France) with Aero Concept engineering.
Got a lot of answers about all the products and position.
I will post it one thing after an other in a website (in french but still the watts are the watts so you may understand even if you don’t speak french.
Website opening in 1-2 weeks. almost done
