I have previously worn the Brooks Ghost 14 size 12 2E and the Asics Evoride 2 in 12 2E. Both of these shoes fit good, and i would buy again. That being said, i cannot find a carbon plated shoe that is 2E. Are the wider feet people out of luck or am i missing something?
I used to wear New Balance in 2e, and have had success going a half size up in Nike in their normal widths. I went from 12.5 2e in New Balance to 13 for Nike no issue.
I’m pretty sure there are no carbon plated 2E’s out there.
Does not seem to be many but found two (and a half):
New Balance FuelCell SuperComp
Asics Magic Speed 2
Altra Vanish Carbon (not technically a 2e and with a “half-plate”)
Asics Magic Speed 2
Awesome, that asics magic speed 2e is exactly what i was looking for! Can’t believe i missed that! Thank you!
Asics Magic Speed 2
Just got a pair of Altra Vanish Carbon to test, and have done by 1st impression run. What real stands out is how stable they feel. This is a common comment in almost all of the reviews I have read. The stability remains even off camber and around turns. It is the most impressive “ride†I have ever felt in a shoe. Definitely should be on everyone’s list to check if your considering a Supershoe, and particularly if you have wide, or wide ish feet.
