Almost every coached swim session I have ever attended has gone something like this:
W/up
drills
Intervals
W/Down
As a result, even now I am not coached, all my swims are variations of the above. Occasionally I will do a straight swim, but that is the exception. When I swim, I feel I get rapid improvements from intervals of 50m-400m. If I have done a couple weeks of just straight swims, I don’t seem to get much benefit.
So my question is: Except for a few, why shouldn’t all of our bike rides and runs have the same format? I know that technique is very important for swimming, and that because technique falls away quickly in the water, breaking sets into distances that you can hold stroke for is important. Also, intervals in the pool are a lot less stressful on the body than running intervals. But running injuries from intervals are not a factor of speed but of poor technique, which could be limited by working on drills/technique.
Since buying a computrainer in 2007, I have done a lot of interval training on the bike which has made a massive improvement to my biking compared to my years of steady rides. Running is tricky because it carries a high injury risk, but if you do specific running drills and keep the intervals manageable, wouldn’t it be better to do this than straight runs?
So instead of a straight 45 min run, your runs might look like this:
Warm up - 10 Mins
Drills (strides, quick feet, high knees, crossovers, bounding etc) ~ 10 Mins
Intervals 5x4mins
W Down - 5 mins
And similar for the bike.
This would mean that you work on running drills and cycling drills EVERY ride/run and do intervals EVERY ride/run. The intervals would obviously vary in length and intensity, but if this format is the best for EVERY swim session, then why not for EVERY bike/run session.
Having read many of the posts on weight training, I am in the “If you have limited time, then better to use it swim/bike/run than doing weights” camp. So if you apply that to bang for buck in training, if you are limited to 3 sessions per sport/per week, then what is the value of steady/straight sets when intervals,drills is going to deliver more for you?
N.B I am not a coach or profess to know much about training, so please feel free to shoot me down if my logic is crap!!
Will
