Why do my nipples hurt?
Yeah, I know kind of a weird question. I did my first sprint tri yesterday after 10+ years of not doing tri’s. During the run portion my nipples really started hurting. They continued to hurt after the race and for the rest of the day. They are still tender today. I certainly don’t remember this being an issue back when I was doing tri’s before. The only thing different that I can think of was that I was wearing a new jersey during the bike and run. It was a Louis Garneau Sleeveless Element with their Airdry fabric. Has anyone experienced this?
p.s. I’m a dude so there were no infants feeding on my breats during the run. Just thought I’d get that out of the way.
Sounds like chafing. Did you get in the shower and scream? Wear bandaids next time and no new clothes.
Congrats on your first race back!
Friction. Get some Bodyglide and run it on your nips and other friction-prone spots before you run. Much more persistent than Vaseline.
A little bodyglide on the nips does wonders or in extreme case, nip guards.
http://www.nipguards.com/quotes.asp
Are you a guy or a gal? If you’re a gal, I volunteer you my services to “nurse” them back to full health and wellness.
You weren’t playing soccer against any Italians were you?
I to thought this was a soccer thread
Dirt.
Hey! Where did that ps come from? It wasn’t there the first time I read your post!! I’m so humiliated…
Mine stopped hurting when I removed the teething 9 month old from them…
Body glide and careful selection of running shirts…per my male training partners.
Holy smokes! I thought I was going nuts. It turns out this is a legitimate issue. I sure am relieved. Looks like I’ll be getting me some Bodyglide. I almost always run without a shirt (sometimes a light cotton shirt when it’s “chilly”) so that explains why it’s never been an issue before. I guess you learn something everyday.
Yes, I did get quite a shock when I got in the shower. But, it was nothing compared to the shock I got when I jumped in the pool after the tri to cool off. I was out of there much faster than when I went in. Felt like I someone had dragged me across some astroturf at 50 miles an hour.
Yes, the p.s. was there the first time around. You missed it in your excitement.
Btw, am I missing something with the soccer references.
It’ s French world cup thing . HE must be a A cup I think or less.
At least he got the gold ball’s :slight_smile:
Dirt
Chaffing! If you are doing long runs, best way to prevent is cover them. They have “nipple guards” but way over priced. get a generic store brand small band aids and put them on. But be sure to remove them first before taking off your shirt in public.
Also for shorter runs bodyglide works OK
I don’t know about band aids. I know they’ll work but that seems like an offly delicate area for a band aid. I bet that’s got to hurt when ripping them off.
Baby oil will help to painlessly remove bandages.
I use clear bandage tape sold in the “scotch tape dispeners”.
I fold both ends over slightly so I have a grab-strip to pull it off. Removal does not hurt and I am somewhat hairy.
I have used nip guards also and they are overpriced and look really “dorky”.
bandage tape $4 for around 100 runs vs. nip guards $9 for 8 runs vs. band aids $2 for 25 runs
Forget the bodyglide, glue, or the nipple guard rip off, simply go to the drug store and find a box of the small circular band aids for $1.89 and use them, problem solved. Oh, be careful when you remove them if you have nipple hair, or do it in the shower.
If you ran with a shirt on more often in training, your nipples will “toughen up” a bit. Then you probably won’t have the problem when racing. I usually have this issue once or twice early in every season, then the problem just goes away due to that area getting naturally tougher (unless I run long in the rain).
Not an uncommon sight at marathon finish lines are guys whose nipples have chaffed so badly that they’ve bled through their shirts. Tough way to learn a lesson! The band aid/nip guard solutions are decent ones but I’ve managed to lose these occasionally through sweat or dumping water on me (not to mention the look of these things under a shirt can be just plain weird). Don’t imagine this would be a problem at a sprint distance but for longer stuff you might also want to experiment with what you are wearing on top. I’ve found that wearing a top that fits very closely works very nicely for me. While it doesn’t do much to accentuate my less-than-elite-level physique, it does limit the amount of sliding of my jersey fabric and stops my chafing problem.
I can tell you first-hand that it’s not fun once it gets past the hurt stage. Here’s what happened this weekend when I went from sore to OUCH…
http://www.juric.org/images/ouch_crop.jpg
I think pasties are the solution. with tassels.
