Getting a P3 shortly (in order), I plan to put a torpedo bottle on the Tri bars and use my jersey pocket for a second bottle. But I’m still not 100% sure. I may use a smaller water bottle in my Jersey with concentrated calories with the plan being that as I pull up to a my torpedo bottle will have been emptied and will have some concentrated mix it, the I’ll pick up one water bottle - maybe two if it is hot, depending upon stops and dump the water bottle in the torpedo, drinking the rest.
If it were hot I’d likely go with 2 water bottles and have both in my jersey.
If you can fit water bottles comfortably in your rear pocket of your jersey, I would suspect that you might look for a better, more tight and aero jersey…just sayin’
I put a bottle between my arms and that is it for a HIM - just get another bottle of whatever the course drink is…experiment with gels that go down with any liguid - Hammer Gels are what I use, they go down fine with water or gatorade type drink.
Keep it simple. Wrap your spare tube, tools tight under back end of seat with velcro.
Unfortunately, I’ve found that the typical triathlon racing suit has very small pockets, well, at least my DeSoto one-piece does. It’s really hard to cram a bottle back there on race day.
In training, it’s very easy - just wear a bike jersey, and you can put 3 friggin’ bottles in the (loose) rear jersey pockets and one between the arms. You can do an entire ironman training ride like that no problemo, no support.
I ended up putting a second bottle holder on my P2 frame so I have one between the aerobars and one on the frame. Really easy to grab/swap as needed. I almost went one bottle, but I find that the bottles on course in the races I’ve done have been so flimsy that they feel like they’re going to fly out any second, so I don’t really trust them.
Just ordered my P2 yesterday. I have been out of tris for 1.5 years but on my first bike (a P1) I carried no bottles for all the sprints I did. I’ll do the same this time. I figure I won’t be trying to podium in the HIM I’ll be doing so I am just going to put a bottle on the frame and roll with it.
Same for long training rides with a bottle or two in my jersey like mentioned.
I aspire to get to the point where there is a difference in my times between wearing a tight Tri suit versus a tight Cycling Jersey. Until that happens, I’ll be continuing to stuff shit in rear pockets.
Do you SWIM in a cycling jersey under the wetsuit?
I also wear only cycling jerseys during training, mainly for the rear pockets, but it’s definitely suboptimal under a wetsuit on race day.
Nope, only wear Tri shorts under my wetsuit. That’s why I then ride with a cycling jersey. Using a full zip, it is quick to put on.
an elite crono is about a wash on the downtube(of a p5) yes, a slight penalty but not much of course you cant toss and replace in a tri. gets expensive fast
