Long story short, I should have bought two of them when I had a chance. It has a slotted center, which allows the attachment of a mount directly to the face plate (which Barfly still appears to make).
Here’s the issue, i don’t know where I could source this faceplate.
I’ve been looking for one of those for a while, and they appear to be sold out everywhere, including at 3T. 3T appears to have discontinued that stem, so doesn’t seem likely we will see more of those made.
FWIW, the stems that Cervelo is making for their newer road/gravel bikes (as per Dan’s review here) have the same style slotted faceplate (they even use the same Barfly mount) and they are available aftermarket.
Those F3 mounts that Anne mentioned are pretty cool… we wrote about the OE version they did for Lezyne here, and we’ve got pretty much their whole line of products in for test and review right now, look for that on the main page soon.
I know them!
Coupla guys from Chicago…bike racers…artists…engineers…
Ah, very nice
Btw, i have gone back to Craig quite a few times since we moved to cycling mecca of the midwest. Think (fingers crossed) the tweaks he made means that my knee woes are finally behind me. Actually am able to ride my TT bike after a two-year hiatus.
Thanks, that was quite informative. I presume the F3 won’t work on my current stem (Arx II) or any other stem where the bolts are that close together?
If you’re looking at F3, look at Fetha as well. They go down to 9mm bolt spacing and weigh about the same (3 grams lighter)
I was deciding between these two and went with Fetha because it looks more solid (made to size instead of two swiveling pieces). But if you change stems you’ll need a new bolt mount for it.
