Where buy online m5 x 80mm bolts?
I need 4 80mm M5 bolts that are countersunk and prefer have a hex socket head.
Wow I have been searching the web for 30min+. It is amazing that this type of bolt in a countersunk with hex socket head is that difficult to find in the US. Found several online locations in the UK.
I would prefer to buy locally but after doing lots of calling around does not look possible.
Thanks for any help.
McMaster.
http://www.mcmaster.com/#machine-screw-fasteners/=egn7b6
A quick search turned up some M5 80mm bolts, but no hex heads.
Appreciate it. I have purchased other bolts from McMC and had seen the bolts with the phillips head. Hoped for hex head. Guess I could torq a phillips head.
I actually found a socket head cap screw on Grainger: http://www.grainger.com/Grainger/socket-head-cap-screws/screws/fasteners/ecatalog/N-8n7Z1z0o3ppZ1z0nyv1Z1z0nzsp
I always use McMaster, MSC or Grainger to fasteners.
may want to try these folks:
http://fairwheelbikes.com/
chris
You might also want to look at boltdepot.com
I’ve always received good service from them
I buy from these guys:
http://www.fastener-express.com/
They take paypal and deliver super quick.
BTW, I use stainless bolts for everything on my bikes. Saves a lot of problems later when you need to do maintenance…
Amazon has a surprisingly good selection of fasteners:
http://www.amazon.com/s/ref=nb_sb_noss?field-keywords=m5+80mm+hex&url=search-alias%3Daps&x=0&y=0#/ref=nb_sb_noss?field-keywords=m5+80mm+hex&url=search-alias%3Daps&rh=i%3Aaps%2Ck%3Am5+80mm+hex
I appreciate all the sites. Unfortunately going through each of them none of them offer a M5 that is 80mm long with hex and counter sunk.
It just seems amazing that this is so difficult to find.
I have also called about 20 places. Lots of interesting places like Racebolts.com that specialize in weird bolts but no go. Racebolt gentlemen suggested that most come to him for really odd sized bolts and if he does not have them then no one would.
After lurking on this site for about five years, I registered just to solve your problem. Get a longer one and grind it down.
I thought we were supposed to be smarter than the average athlete.
I would be all over that if I could find a longer one. Looks like the longest is 60mm. I thought I was already being smart milling my own risers out of aluminum. But should have figured out where I was going to get the bolts first.
http://www.torontocycles.com/index.html
If you want Ti bolts, I like them because they don’t chip/flake/rust
I guess you better start making your own bolts too.
are these what you are looking for?
http://www.boltmeup.com/m5-x-80-high-tensile-strength-129-allen-cap-bolts-10-3167-p.asp
McMaster http://www.mcmaster.com/ is your friend… that place has every freakin bolt known to mankind
I actually found a socket head cap screw on Grainger: http://www.grainger.com/...o3ppZ1z0nyv1Z1z0nzsp
He needs countersunk, as in the type used by Profile Designs armrests. Sounds like he made custom spacers (something I was debating doing as well).
Yes you would definitely think McMC would have it but no dice. Either no countersunk or no socket head. Otherwise everything good. Buy 10 at a time. Reasonable shipping. I have purchased many things from them and shipping is fast to here.
I would really consider making my own but I don’t know how to create a socket head. Have no idea how to cut such a small square in the head
Let me check my tool box. I purchased some a couple years back to get my armrests up a little higher. PM your address to me, and I will throw some in the mail
Wow thanks a ton! I PM my physical address.
They are very close but I really needed a countersunk head.
This question has come up on the forum a few times without a source. I would really like to find a place so it can be shared with others with the same need. I have also seen the need on other forums.
