What's this noisy!
Hi
I need some help and I’m not sure where to go from here. I need a bike mechanic and fitter! :slight_smile:
Bought a felt ia10 about a year ago (marked down). Rode a few times on the trainer. I was still getting used to it …
Then I moved to Canada and bike got damaged during shipping. 3 and a half months later, new frame arrived. (Yes, that’s right. It took that long) Pick up bike from local bike shop that put it together and first ride on trainer I hear this really noisy racket from drivetrain.
Shop says it’s the best they can do and to make smooth I need a new crankset. They said mixing brands like that will never be as smooth. (Not sure it was like that before moving…)
I also know right now my fit is off. My old felt b 14 was comfy!
Thoughts?
trying to post video…
it’s not as bad as when I picked it up
some gears are ok
but some are still pretty bad imo
https://photos.app.goo.gl/3odRMdqGDAuZfU366
Need more info. Rear derailleur, cassette, chain, crank, etc. what’s the setup?
Looks like you’re in the biggest cog in the back (cross chained). Does it do that in other gears?
That sounds like a 10s chain on an 11s cassette. Or, very stretched chain.
The brand of crank is fully irrelevant.
Is the drive train new?
I didn’t change anything from what came with it. What might be different from stock …
Front derailleur r8050
And rear derailleur r 8050 ultegra di2 11 speed
Does that help?
The crank set that come with the bike is made by vision.
And yes, the most noise is when I’m in the big chain ring and the first couple of the big cogs.
I bought a chain from premier, haven’t tried it yet.
The drivetrain is very new!
Stop crosschaining.
Is that an 11s cassette?
Yes, 11
The rear derailleur hanger might be bent.
Stop crosschaining.
Ok
Possible chain too short. And crosschaining.
Shimano cranksets are quite noticeably quieter than aftermarket ones, especially when cross chaining.
Short chain stays and short chains make it worse.
Had to look up chainstays… :confused:
Would you still call this cross chaining?
https://photos.app.goo.gl/g4U1499idafbKLJZA
https://photos.app.goo.gl/PB2MbSX9PXwfx6qM7
both videos are in the same gear
It is a regular skipping sound, like the chain is trying to move to a different gear. I think it is on the third cog from the biggest, so that is not crosschaining and should not be noisy. It sounds like the rear derailleur is mis-adjusted. It is possible that it is chain rub on the FD, but I don’t think so. Can you see if the chain is touching the FD cage? Or, can you tell if the sound is definitely coming from the RD area?
Can you post a profile picture of the RD installation? I am curious if the little direct mount extension part is installed and if so, whether it is correctly resting against the tension stop. (It should be extending rearward, horizontally from the mount point.)
At first I thought it was the front, but I now think it’s from the back. I can’t see where it would be touching my FD cage
It’s like the chain doesn’t fit or yes the RD is off for those gears
Is this helpful?
https://photos.app.goo.gl/MtTTGfQnAfHSR6M66
Is this helpful?
Yes, that picture helps. The RD is installed correctly. I have seen a few cases where the new Shadow derailleurs for direct mount were attached incorrectly.
There is a process to align the RD with micro adjustments. Maybe the shop did not follow the Shimano process. Also, it looks like the cage is extended further forward than mine in that same gear combo. But, my bike is not on hand to compare now. (I have an IA16 with the same Di2 drivetrain as yours.)
Thanks!
So you have vision mixed with shimano
I will look online or find a shop that might want to help.
I am not very familiar with DI2, but I guess I would/could/should learn! :stuck_out_tongue:
So you have vision mixed with shimano…I am not very familiar with DI2, but I guess I would/could/should learn! :stuck_out_tongue:
Sorry for the confusion… I only have the R8050 Di2 FD & RD. I have a SRAM Red 22 crankset. (The comments about non-Shimano cranksets are bogus. Many, many bike makers package other cranksets with Shimano shift bits for a lot of very good reasons.)
This is Shimano’s user guide for your Di2. Go to page 129 and follow their process for aligning the RD. It is very easy.
http://si.shimano.com/pdfs/dm/DM-R8050-02-ENG.pdf
Many thanks!
Appreciate it
Also found your thread about Di2 install
NICE!!
