What's the "virtual" CdA and Crr of the LeMond Revolution?
That’s a question I’ve been interested in quite awhile…and with my getting access to one recently, I decided to run a few tests/analyses.
Just in case anyone besides me was interested, here’s the result of a constant cadence cassette sweep (only 9 of the 10 cogs of a 12-25 cassette, 60 rpms, with a repeat of the 53-14 at 75 rpm for some slightly higher power.) After the sweep, I did some accelerations/decelerations for the purposes of doing some inertial mass estimates (more on that later).
http://i54.tinypic.com/333e53n.jpg
Taking the average of the power and “virtual speed” (i.e. the result of the gearing, cadence, and assumed wheel rollout) over the last 2 minutes of each step (and the last 1 minute of the 75 rpm step), I then plotted P/V vs. V^2 for the following:
http://i53.tinypic.com/rubg5z.jpg
Assuming an “all-up” mass of 85kg, and a rho of 1.2 kg/m^3, that y-intercept works out to represent a Crr = .0051 and the slope of the line works out to represent a CdA = .350 m^2. Sounds like a fairly “normal” road bike position (on the hoods) and Crr.
Now…about that estimate of inertial mass. My intent was to plug the file and the calculated Crr and CdA into my VE spreadsheet and then modify the mass entry until the small “hills” formed by the accelerations/decelerations “flatten out”…I tried that, but I think I need to reconsider how varying the mass entry affects the calculated rolling resistance force (I might need to separate out the mass terms used for the rolling resistance calcs and the other places the mass term is used). Although, with an assumed 85kg mass, it’s pretty darned flat as it is. (I actually had to slightly increase the CdA to .353 to flatten out the “steps”)
http://i56.tinypic.com/2iw6dmu.jpg
I think I might just pull the fan/flywheel cover off and measure up the flywheel and just manually calculated the moment of inertia :wink:
What happens if you accelerate more gently and then coast down (e.g., make the speed trace look like a triangle)?
Here’s what the speed trace looks like from the accel/decel section…I guess I accelerated faster than I’d thought. My intent was to give it a big “signal”…but yeah, maybe I need to be a bit more gentle…
http://i56.tinypic.com/xemc8.jpg
Can you overlay the VE on that speed trace?
Is this thread available in English?
awesome. I love this stuff. I’ve been playing with this with my KK since I got a powermeter. I’m going to have to “Chung” myself once i get a free saturday.
Like this?
http://i56.tinypic.com/20fch93.jpg
Sure…quick translation…I wanted to quantify just how close the Revolution “mimics” riding outside and this thread is showing how I’m doing that. So far, the “load curve” of the Revolution appears to match VERY well the “typical” aero drag and rolling resistance of riding your road bike outside on perfectly level ground. I was able to determine this using the same method one would use to field test to determine aero drag and rolling resistance outside using a power meter.
The last piece of the puzzle is determining how well the flywheel “mimics” the inertial mass of a rider+bike traveling down the road at the same indicated speed. I tried doing that using Robert’s VE technique and the coefficients measured above. That’s what Robert and I are going back and forth about…
Up to speed? :wink:
Aha. Excellent. It may “coast” better than regular trainers – but not as well as a bike on a flat road. Likewise, it appears to accelerate faster than a bike on a real road. Steady state load is reasonable, though.
I presume you were using an all-up mass of around 80kg? So cut that in half to 40kg and double the Crr to .01. That’ll keep the steady state power the same but should improve the modeling for the KE component.
Doesn’t anyone just ride their bike anymore?
why do you have to be an ass?
I believe it was Lao Tzu who wrote “To become learned, each day add something. To become enlightened, each day drop something.” So, in that vein, I am considering moving past the gaining of knowledge through the use of power meters and embracing a more zen like approach to training.
In looking back at my wording, I can see where my question could be misinterpreted. Mea maxima culpa…
Yeah…I thought of the same thing last night. Just modify the Crr to compensate for changing the mass so that the rolling resistance force stays constant. I just haven’t had a chance yet to try that…
I thought this was the most interesting thread in the past week or two…
Lemond is selling their “Power Pilot” for, what, $400+? With Tom’s info, you can print out the cadence-gear-power combos on an 8-1/2" x 11" sheet of paper and scotch tape it to the wall. Send 10% of the savings to Tom.
…except that doesn’t provide one with a downloadable record of the session :wink:
Work with me.
So use a computer that logs cadence and rear wheel speed. It’s simple spreadsheet math from there.
Here’s the “best fit” I could find…and I mostly judged it off of the final “tail” which was a coast down to zero rpm. I adjusted the mass (and Crr accordingly) until the final steady-state leg and the coast down to zero had a minimum of “disjoint”. This case was actually 100 lbs (45.5 kg) and a Crr of .0094
http://img208.imageshack.us/img208/7521/lemondve455kg.jpg
Now…we’ll see how close that is to a calculated mass based on the flywheel geometry! http://wattagetraining.com/forum/images/smilies/icon_e_smile.gif
