I currently have a 19mm clincher rear wheel with a wheel cover. I run a 23mm tire (conti pro race3).
Any guesses what would be the time saving in moving to a 23mm wheel, over a 40K TT?
NOTE: I’m not asking if it’s worth the money. I’m just looking to guestimate the time savings. How much I’m willing to pay for those seconds is up to me!
I doesn’t know the answer. I don’t recall if anyone has clear numbers on the drag difference. Perhaps Vince@HED can provide data on the old jets vs the new or something, with 23mm tires on each?
Oh right… Cervelo P2C. Although after doing some winter bike fits I might go to a P4 if I conclude the fit makes sense… (or this PX nonsense if it exists)
Hmmm…sorry, I know it’s not what you asked for but on a P2 I’d go the other way…keep what you have and find a narrower low crr rear tyre. Are you thinking of replacing the rear with another (wider) training wheel that’ll be covered, therefore keeping the same shaping of the disc surface area? Going to a wider rim may help slightly with a smoother transition from rim to tyre (ie, reducing the “bulge”), and of course there may be some other spin-offs like rolling resistance, comfort, etc, but from an aero perspective you’re still left with a wider rim/tyre combo on a frame with somewhat average rear wheel coverage.
And what’s a “conti pro race3”? Not what you asked again, but either way there are faster tyre options…
Something like that. I’m looking for the fastest setup that would allow the cover to be removed so the wheel w/powertap can be used on my road bike.
Doh, sorry. Michelin pro race 3. I thought it was decent? What are you recommending over it?
I have the same bike and wheel as you and have mainly used either a mich pr3 race 23mm or a Bontrager aero TT 19mm.
The PR3 bulges out a bit too much
The Bont. is a very low profile tyre that blends really well with the wheel and disc, but gives quite a jiggly ride on rough roads. I prefer to save it for my hed3 front as those tires are now hard to find and it is one of hte best for a hed3.
I have just got fitted a 23mm conti gp4000s and it seems a good compromise. It bulges less than the PR3, is less jiggly than the Bont. and gives a bit of a better ride with similar rolling resistance to both the other tyres. It also feels like it last longer.
I wouldn’t bother switching to a 23mm rim.
For example, why sould the “Michelin Pro 3 Race (25)” (which I assume is 25c) test better than the “Michelin Pro 3 Race (23)”
!(…/…/images/clear_shim.gif) !(…/…/images/clear_shim.gif) !(…/…/images/clear_shim.gif) !(…/…/images/clear_shim.gif)
Because a wider tire has a lower Crr, all else being equal.
Interesting chart, havent seen that before. Here’s a dumb question regarding that data…whats faster: a lower or higher crr? How about that watts per wheel data column? Better to have more watts per whee? Or is that how many watts required to run at a 100 rpm cadence? Thanks
Bike tech review used to have a ‘pay-for’ report on “The Importance of Tire Selection”. It focused mainly on they aerodynamic difference between a 20c vs. 25c tire on a Zipp 404 and Hed 3 wheel.
