Whats a good swimming drill workout
I’m finally able to swim again, and I need to reacquaint myself with balance and form.
What would you guys do for a 2k drills workout?
thanks.
How does 40 x 50 on:50
Shut up
Don’t you have people to drug or something?
Hi there,
This is US Pro and certified USAT Coach Ruthy Vesler. I would recommend doing 1 arm swimming. Try both with your non-swimming arm to the side and with your non-swimming arm out in front for balance. Breathe towards your non-swimming arm. This will ensure that you are getting enough rotation to get a breath. If you are not getting enough side rotation, you either won’t be able to get a breathe or you will be forced to lift your head completely out of the water which will mess up your balance completely. Also, make sure that you can see your fingers out in front of you to make sure that you are getting enough reach.
I hope this helps!
And if you are in San Diego this spring be sure to sign up for my Triathlon Swimming 101 Clinics. (www.active.com)
All my best,
Ruthy V.
ruthy@irondevilgirl.com
www.irondevilgirl.com
Shut up
Even though you are acting like your log in name I’ll help out go here .
That’s great. I did a search and I didn’t see that thread. Thanks
