What year are these HED wheels?
Not sure what year these are. Does anyone know? I do not see any serial numbers or anything written on them.
Thanks
I am going to guess about five years old.
check under the rim strip for serial number
I will guess 2012-2014. SCT profile. The trick would be to know how many iterations their were once the SCTs were introduced. One clue would be if the rear hub is 11 speed compatible.
I looked there. Nothing. Thanks for the help.
Thanks
Looks like a decal kit on old wheels. 2012 is generous. I’m going with ~ 10 years old - or more.
Thanks for the info.
I will guess 2012-2014. ** SCT profile**. The trick would be to know how many iterations their were once the SCTs were introduced. One clue would be if the rear hub is 11 speed compatible.
this. also, the disc is made in USA, which would suggest it’s likely made faily recently as HED started bringing production in house. I would say perhaps even newer than 2014 as some of the discs from last year were still made abroad (Spain is what i heard from one source)
Hed Jet 60 C2 (prior to the plus models) front. Hed Jet C2 rear disc. I have a pair of these 2015 models.
I was pretty sure that all HED wheels have a serial sumber on the rim under the rim tape/strip…
It shows the date of manufacture, and the number of wheel on that day.
I have a 2012 Jet 90 and it has the woven look but mine are 650’s and may be a year behind. I’m thinking these are at least a 2012 and likely a 2013-14.
Look again under the rim tape. All HED wheels have a serial number (at least the 8 wheels I have)
Thanks for the info. I will take a better look.
I have almost the same wheel set from 2012, but my front wheel has the carbon/chromed hub, which is older that yours. So I’m guessing they’re from 2013 or newer. Not super new either since they’re not “plus” models and I believe only makes “plus” wheels now.
Thanks. Any info is great. I’m going to list them for sale when I get a few minutes.
Based on the front being UD, I am guessing it is a HED Jet 4+. The disc is older.
