My last multi-sport event was in 2008. I have a duathlon coming up at the end of the month and just realized I have nothing to wear!
Any suggestions that won’t exceed 200 freaking dollars? 150? 120?
I’m considering wearing my cycling team skin suit… anyone try that? I’ve never run in it so I guess I’ll try that first.
I would wear a trisuit of some kind. I wouldn’t want to run in cycling kit or bike in running shorts, so the trisuit makes an acceptable compromise.
I’ve done lots of Du’s in a skinsuit, and they work fine (just leave the top unzipped on the runs for cooling and freedom of movement). The chamois isn’t a big issue since it’s not soaking wet from the swim.
Trisuits work fine as well.
DuDooD
March 5, 2012, 2:05pm
4
I wear tri shorts and a tri top.
If you can run in the skin suit, you’ll be fine
jaretj
March 5, 2012, 2:10pm
5
Personally I would wear the same thing I do in triathlon
jaretj
The cycling skin suit works real well.
The chamois isn’t a big deal unless you sweat like a pig!!
Pretty much the same thing I wear in a triathlon. Tri top and tri shorts. Just add socks if you prefer.
If someone is as fast as Kenny was they can wear whatever they darn well please.
