What small device can I use to run Zwift on my Treadmill or at a hotel or something?
I don’t own a great phone. What other alternatives do I have for viewing zwift, specifically on my treadmill which has a kindle holder or when I am out travelling and want to hook it up to the hotel gym or get a ride in at a cabin.
If you’re able to pick up a used iPad that’s what I would recommend.
I use a 1st generation iPad Air with a cracked screen I picked up on eBay as my primary Zwift device (home and on the road). Works fine and was much cheaper than buying a brand new one.
What footpod are you using? I’d like to try out zwift running but the $30 zwift pod has some pretty terrible reviews around it.
I thought of this:
https://www.dcrainmaker.com/2019/01/treadtracker-treadmill-accuracy.html
Then realized you must already have a way to communicate your run to zwift – just need the machine to do it. As others have said, a used tablet is an inexpensive way to go.
I decided not to calibrate mine and it works fine out of the box. I’m only doing static runs at 7mph (8:34) on the treadmill, so it’s pretty well spot-on for that.
I think GPLama also has a YouTube video up about the different foot pods, might be worth a watch.
I’ll give it a look thanks!
It’s 2019, time to buy a modern phone.
what phone runs zwift?
to whoever asked, I use the garmin footpod
Question on the IPAD, I never used Apple before, will it be the same USB setup with the garmin usb stick that I use on my pc for zwift to capture the data from my crank or smart trainer? That same Garmin USB stick captures my footpod data as well. Curious if everything works the same on the Ipad air. Thanks everyone. It certainly looks like a good option for when I travel and want to bike in the hotel or run in the hotel gym and capture data on zwift.
I use a Galaxy 9 or a Huawei MediaPad M5 with a bluetooth footpod
